  #16 (permalink)
Old 04-02-2009, 09:27 PM
Dealer : Miller Toyota
2005 Toyota Sequoia
Last Online: 11-22-2009 12:04 AM
MadStacker is on a distinguished road.
MadStacker's Photo Albums
Default Re: New Solution to the Clunking problem?
One thing I noticed with our Sequoia is that if you grease the rear driveshaft slip yoke, the excess grease does not weep out anywhere. It just forces the driveshaft to get longer, thus not allowing the slip yoke to compress at all. Has anyone ever ran into this. Most driveshafts will allow the excess grease past the splines and then either spit out the dust seal or a weap hole in the middle of the yoke itself.
I ended up taking the shaft out, removing all the grease and then put a light coat of synthetic grease on the splines.
Jerry
  #17 (permalink)
Old 04-04-2009, 04:36 PM
Dealer : Toyota Walnut Creek
2007 Toyota Sequoia
Last Online: 08-04-2009 02:23 AM
mtufenk is on a distinguished road.
mtufenk's Photo Albums
Originally Posted by Babeo74 View Post
I'm having those same symtoms. I have a 07 sequoia 4x4 and my dealership here in hawaii state that there is no TSB for this problem. Did this fix your problem?
The TSB for the clunking sound is 2wd only. I also have a 07 4x4 and took it in for the TSB repair only to be told after 6hrs in the shop that the TSB is for 2wds.
They told me to bring it in and speak directly with the shop foreman and let him test drive it with me.
  #18 (permalink)
Old 04-04-2009, 04:57 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
If it were me, I'd probably replace the driveshaft. There is a TSB for Tundra 4x4's and Sequoias are Tundras for the most part.
But thats me, and you didn't hear that from me.SHHhhhhhhh
The test procedure in this TSB will tell you if it is the problem.
25 yrs with TOYOTA
  #19 (permalink)
Old 08-04-2009, 02:22 AM
2007 Toyota Sequoia
I finally got my 07 4x4 back into the dealer to diagnose the clunking problem. The earlier Sequoia TSB did not apply to my car since it is for 2wd only. I also brought the Tundra 4x4 TSB dealing with this very same issue. One of the technicians from Toyota HQ happened to also be there that day. After several hours they deemed that what I experience was "normal" and there is no fix issued from Toyota dealing with this. They would not apply the Tundra TSB becasue its not for Sequoia's. What recourse do I have? Is there a way to complain to Toyota about this issue?
  #20 (permalink)
Old 08-04-2009, 02:40 AM
08TexasTundra's Avatar
Last Online: 11-16-2009 12:33 PM
Images: 24
08TexasTundra is on a distinguished road.
08TexasTundra's Photo Albums
Is there a TSB for the 2008 2WD Tundra, I have the clunking noise going from a dead stop and during turns on my 2008 Toyota Tundra 2WD Crewmax, and I am hoping they have a fix for this problem; as I will have the truck in the body shop this week or nxt. I got into a wreck recently but the noise was there before the wreck and was actually there from day one.
Please give any advise you have. I have read on the forums about a clunk on the 4WD but have not seen anything for the 2WD.
Please advise Mustang or anyone else who has any knowledge of this problem.
Thanks in advance!
2008 TOYOTA TUNDRA TRD SR5 : BILLET GRILLE, X-Tang bed Cover, Carved 20", towing mirrors, chrome handles (OEM), hopefully soon to have TRD Sway Bar, and hopefully more to come as money comes my way!
  #21 (permalink)
Old 09-15-2009, 02:38 PM
2003bajatundra4x4ac's Avatar
Last Online: Today 09:23 AM
Images: 5
2003bajatundra4x4ac is on a distinguished road.
2003bajatundra4x4ac's Photo Albums
i've got a '03 that is doing this. do they not cover in the tsb because my truck is out of warranty? what will happen if i don't address it?
