Old 03-03-2009, 02:53 AM
Dealer : Toyota Walnut Creek
2007 Toyota Sequoia
Last Online: 08-04-2009 02:23 AM
mtufenk is on a distinguished road.
mtufenk's Photo Albums
Default New Solution to the Clunking problem?
I took my 07 in for the 15k maintenance. I told the mechanic about the clunking noise I hear when I start from a dead stop (which progressively gets worse the closer I get to the next service interval). I have read on this forum that its a design flaw that is normal and requires packing of grease somewhere toward the read of the drivetrain.
The mechanic told me of a new TSB that came out about 2 weeks ago that addresses this problem. The TSB claims its due to the "joint between the rear transmission mount and the frame crossmember" and provides instructions in the TSB on how to replace these parts.
The dealer has ordered the parts and will be free of cost since the car is still within the powertrain warranty.
I always thought the noise was an internal problem but the fix is external.
Has anybody had this fix completed on their Sequoia and did it solve the problem?
Old 03-03-2009, 09:37 AM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Default Re: New Solution to the Clunking problem?
It's worked on the last 2 Tundras we did
25 yrs with TOYOTA
Old 03-03-2009, 09:56 AM
Dealer : Vicksburg Toyota
2006 Toyota Tundra,
2007 Toyota Sequoia Black Limited
Last Online: 10-08-2009 07:30 AM
brentdom is on a distinguished road.
brentdom's Photo Albums
Is this TSB for the Tundra also and is it for both 2WD and 4WD? When I bring the truck in to the dealer will they know about the TSB or should I bring a copy of one printed out and from where?
Old 03-03-2009, 10:26 AM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
YEAR(S) MODEL(S) ADDITIONAL INFORMATION
2005 – 2007 Sequoia Drive Type(s): 2WD
Transmission(s): 5AT
VDS(s): ZT34A, ZT38A
2005 – 2006 Tundra Drive Type(s): 2WD
VDS(s): ET341, ET381, JT321, JU321, RT341,
RT381, RU341
25 yrs with TOYOTA
Old 03-04-2009, 06:13 AM
sequoiasoon's Avatar
Dealer : Competition Toyota Scion of Middle Island
2003 Toyota Sequoia,
- Other - 93 Corolla TOTALLED!
Last Online: 11-03-2009 08:17 AM
Images: 8
sequoiasoon is on a distinguished road.
sequoiasoon's Photo Albums
RT381, RU341
Mustang,
What parts are changed/fixed and would it do anything for prior years (03)?
Old 03-04-2009, 09:28 AM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
Nothing in print from Toyota. We have found that if the driveshaft has a slip yoke, all the grease needs to be cleaned out and then we lightly clean all the debris, dirt, caked on grease,rust,ect... from the slipnes and then polish them with some very fine sandpaper, then re-assemble as it was taked apart and lubed with a teflon paste grease. We have some from Ford that we use. We also have found that some of them that do the "BUMP" thing from behind have "U" joints that have 1 small spot (notchy) in them that are binding. It is not enough to call bad by most people, but if your very delicate upon inspection you can feel it in your hands when you move the joint back and forth. It's so very slight of a NOTCH feeling most people would miss it and call it normal. Like I said I have no official proof, this is just what we have found. This applies to Tundras,Sequoias,Tacomas of all years 2wd & 4wd. The 2wd's do not usually have a slip yoke to take apart and clean, so thats USUALLY a notchy "U" joint.
25 yrs with TOYOTA
Old 03-04-2009, 01:24 PM
2006 Toyota Tundra,
I have the "bump from behind" problem. If that is a "U" joint problem, is that something Toyota will fix if its within the warranty for the drivetrain. I have been telling the dealership to grease the zerks when I bring it in for an oil change, but if they are willing to fix the problem instead of the symptom, it would be better.
Old 03-04-2009, 03:00 PM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
A driveshaft issue , should be 5/60 if it is a "U" joint issue, the cleaning/rust/dirty usually is not.
25 yrs with TOYOTA
Old 03-05-2009, 01:26 AM
2007 Toyota Sequoia
Mustang67408,
Based on what you have said, I am a little confused with this new TSB repair. What you explained above is what I have read on this forum as the fix. However, the TSB (which is titled "Clunk Noise at Low Speeds when Stopping or Turning") talks about replacing the rear transmission mount, frame crossmember, and 4 bolts retaining the transmission mount to the frame crossmember. It also says this noise may be commonly heard when accelerating from a stop (which is what mine does).
How would this address the problem you just described?
The TSB also says the 'warranty application is limited to correction of a problem based on a customer's specific complaint.' I take that to mean they wont fix it unless you say something.
Old 03-05-2009, 09:27 AM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
We would do like the TSB said
A mechanic’s stethoscope or similar tool may be used in place of ChassisEAR™.
to locate the noise. While performing the TSB I personally would clean and lube the driveshaft and check the "U" joints. TSB's are always recommended as a first repair, but this TSB did not come out until FEB 19/09, so we have had to improvise until now.
07 Tundras also have a TSB
Some owners of 4WD equipped 2007 – 2008 model year Tundra vehicles may experience a
clunk/thunk noise from the rear of the vehicle or a “bump-from-behind” sensation just before or
when accelerating from a stop. Improvements have been implemented on the rear propeller shaft
(driveshaft) to reduce this condition. Utilize the following repair procedure to address customer
complaint vehicles
for replacing the driveshaft for the "BUMP" feeling. So there is no 1 fix, it is a case by case and vehicle by vehicle diagnosis and repair.
25 yrs with TOYOTA
Old 03-06-2009, 01:55 AM
2007 Toyota Sequoia
Thanks. I am taking mine in next week for the repair. I will post my experience.
Old 03-06-2009, 09:20 PM
2006 Toyota Sequoia
Last Online: 06-06-2009 12:10 AM
foak is on a distinguished road.
foak's Photo Albums
Here is the TSB that refers to the:
T-SB-0067-09 dated 2/19/09
Clunk Noise at Low Speeds When Stopping or Turning
Hope this helps.........
Jeff
Old 03-09-2009, 11:27 AM
Dealer : Toyota Marin
Last Online: 07-31-2009 05:27 PM
06TundraofGold is on a distinguished road.
06TundraofGold's Photo Albums
Had my 06 DC in for service last Friday 3-6. Told the Service Writer about a Clunk/thud. Never heard it when accelerating from a standing stop only when backing up then applying the brake to stop. ( I park in a parking garage where I work and I back into my parking space each morning)
Anyway, long story short, I left my truck at the dealer for service they called me about 3 hrs later and said the the clunk/thud noise had to do with the Tranny mount/cross member. A TSB came out from Toyota about 2 weeks ago for this exact problem. The dealer has to order the parts so I will need to bring my truck back in for repair once they receive the parts.
Old 03-31-2009, 09:15 PM
Last Online: 03-31-2009 10:26 PM
Babeo74 is on a distinguished road.
Babeo74's Photo Albums
I'm having those same symtoms. I have a 07 sequoia 4x4 and my dealership here in hawaii state that there is no TSB for this problem. Did this fix your problem?
Old 04-01-2009, 09:31 AM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
There is a TSB for the 07 Sequoia.
T-SB-0067-09 February 19, 2009
Service
Category
Drivetrain
Section
Automatic Transmission/Transaxle Market USA
Applicability
RT381, RU341
25 yrs with TOYOTA
