Old 04-22-2009, 05:01 PM
Dealer : North Park Toyota of San Antonio
2006 Toyota Sequoia,
- Other - 05 AMG E55
Last Online: 09-12-2009 02:17 PM
mcseth2 is on a distinguished road.
mcseth2's Photo Albums
Default Synthetics at 60k maintenance
I will probably switch to full synthetics on my 60k (2006 4wd) service for transfer case, differential, and transmission. I still use Dino oil in the crankcase, but may switch over then as well.
Does anyone have a recomendation on viscosity for each of these? I will probably use Mobil one or AMSOIL for Brands.
Thanks for the recomendations if you can give them.
Old 04-22-2009, 07:05 PM
Dealer : Gateway Toyota
1994 Toyota Camry,
2004 Toyota Sequoia
Last Online: 11-22-2009 10:01 AM
Andy4 is on a distinguished road.
Andy4's Photo Albums
Default Re: Synthetics at 60k maintenance
the differential may already have synthetic from toyota ('04 did). if you change diff and have a posi rear, i've read that you will need an additive.
I use 5w30 mobil 1, and changed transfer case to syn before the winter and could feel the difference starting out cold.
not sure if all greases are syn., but syn should hold up better in ball joints and universals in drive shaft. something to look in to.
transmission fluid is already syn (right ?).
Old 04-24-2009, 11:17 AM
Now thinking of just staying with regular oils. Seems that there is no real benefit as long as you maintain the vehicle as recomended. I am overthinking this whole thing.
Old 04-26-2009, 05:22 PM
JBH1989's Avatar
Dealer : Toyota of Santa Maria
2004 Toyota Sequoia,
- Other - 1991 Isuzu Trooper,
1999 Toyota Camry Tan w/ 1MZ-FE,
- Other -- 1993 BMW 525i
Last Online: 10-17-2009 04:39 PM
JBH1989 is on a distinguished road.
JBH1989's Photo Albums
Oh there is a benefit. Synthetic handles heat much better than conventional oil, so if you do a lot of stop and go or high speed driving, the synthetic oil will not break down like dino oil will.
2004 Marlin Blue Pearl Sequoia SR5 2WD; 60k miles
1991 Isuzu Trooper 2.6L 5spd 4x4; 103k miles
1993 BMW 525i M50TUB25 auto; 286,500 miles
ASE Certified Brakes Technician / Automotive Electrical Specialist
Independent BMW Technician
