Re: Power Antenna
If you buy a new mast, you can compare length. If you are not getting a new mast, then you don't have to worry. The most common problem is the "gears" strip out. If under inspection, you have good gear after the stripped part, and it doesn't appear broken, you are probably ok.
I would bet that 29" is the whole plastic. How far down the whole is the gear? It should be way less than 29"
