Old 05-02-2009, 08:55 AM
Last Online: 05-10-2009 10:27 PM
corygillard is on a distinguished road.
corygillard's Photo Albums
Default Brake Controller Wiring Harness
Hi everyone, new to the site. Looking forward to learning a lot. May even have something to add eventually. I am trying to install a brake controller (Tekonsha Voyager) in my 2004 Sequoia, I bought used and do not have the wiring harness. I found the connector that I could splice and add the brake controller, but my wire colours are not the same as some people have listed elsewhere. I have:
Black with Red Tracer (Thick Wire)
Blue
Green with white Tracer (Thick Wire)
Green
Orange
Most people mention having Red and Brown whereas I have Blue and Orange. The other 3 colours do match.
Am I missing something? Maybe I have the wrong connector but it seems to be the only one in that area. Can anyone help me match them up with the brake controller. Any help would be greatly appreciated. Thanks
Old 05-02-2009, 09:41 AM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Default Re: Brake Controller Wiring Harness
Orange wire is the ground & goes to white wire on brake controller
Blue wire is for brake actuation goes to blue wire on brake controller
Green wire is for tailights
Black/Red = Battery Voltage goes to BLACK WIRE ON BRAKE CONTROLLER
Green/White = not used, this is a special activation wire for some brake controllers
BRAKE CONTROLLER RED wire goes to brake light switch GREEN/YELLOW wire.
Hope this helps
25 yrs with TOYOTA
Old 05-02-2009, 09:18 PM
Green wire is for tailights (What colour does this one match on the brake controller?) Is it the RED as indicated below? Thanks for the response, I really appreciate it.
BRAKE CONTROLLER RED wire goes to brake light switch GREEN/YELLOW wire. ( I don't have a green/yellow wire)
Hope this helps
Thanks again
Old 05-03-2009, 10:42 AM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
The GREEN wire is not used. your brake controller does not have this option
The BRAKE CONTROLER RED WIRE goes to the VEHICLES brake light switch and taps into the green/yellow wire on the vehicle brake switch. This is how it knows your stepping on the brake. I just checked my wifes 04 Seq and it has a green/yellow wire on the vehicle brake light switch, you need the wire that gets hot "12v" when you step on the brake.
25 yrs with TOYOTA
Old 05-05-2009, 09:59 AM
Thanksmustang67408
Appreciate the help, should be what I need.
