Originally Posted by ivory98es300
I know the wire you want is directly behind your headunit. Toyota wired all thier trucks the same regardless whether it had NAV or not. If you pull your headunit and trim bezel, you will find a 2-wire molex plug taped out of the way along the main stereo wire harness. These two wires are for VSS & Reverse + for a video camera. I can't remember which color you want but just take a volt meter and measure each one when you throw the truck into reverse. The one that sees 12v positive is the one you want.
Ivory---I found the molex plug with 2 wires. Black with yellow stripe and a green with orange stripe. I tapped the reverse sense wire onto the black yellow wire and it worked. Thanks a lot. One problem though...My Head Unit (Kenwood DNX-7120) do not automatically switch to reverse cam when I shift the gear to reverse, it will only work when I switch it manually and when I shift the gear to drive the screen turns to black.
What do you think is the problem?
