Old 05-06-2009, 11:24 PM
Dealer : Performance Toyota Of Lincoln
2001 Toyota Sequoia
Last Online: 05-09-2009 09:47 PM
ColdFinger is on a distinguished road.
ColdFinger's Photo Albums
Default Sway Bar Linkage Removal/Replacement
I had a front link break so I'm replacing both front links.
My question is how to keep the lower bolt from turning while tightening the nut because when trying to remove the old links the only way to keep the bolt from turning was to use vice-grips on the balljoint side.
Maybe a new one will install fine because it is not rusted?
Also, any specific torque specs for upper and lower mount (especially the upper with the rubber bushings)?
Thanks.
Old 05-07-2009, 10:48 PM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Today 02:56 PM
Images: 205
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
Default Re: Sway Bar Linkage Removal/Replacement
There's a picture of that captured bolt in here: Downey H.D. Sway Bar End Links Install
You need a 6mm hex wrench.
It's fairly easy with the right tools.
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead
Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
Old 05-08-2009, 10:42 PM
2001 Toyota Sequoia
Thanks. I saw the hex thing after I had the first one out. I tried using the hex while removing the second one but it ended up breaking the hex end out so I ended up using vice grips again, but the threads were so rusted it was almost impossible.
I then took my dremmel cutoff wheel and cut the nut to free it up. Much, much easier.
I torqued the new links, top bolt, to 14#. Hope that is correct. The rubber bushings were squished some.
I thought about putting grease around the bolt/bushings to help prevent rust but instead just put a light coat of anti-sieze on everything.
Old 06-05-2009, 10:02 AM
Dealer : Frank Gentile Toyota
2004 Toyota Tundra
Last Online: 11-15-2009 09:19 PM
Paparentman is on a distinguished road.
Paparentman's Photo Albums
While checking the brake pads yesterday I noticed both my links are broken.
Any place to order these cheaper than the Toyota dealer?
Old 06-05-2009, 05:36 PM
Images: 205
Yes. See here: Downey H.D. Sway Bar End Links Install
Very inexpensive upgrade from OEM.
Old 06-07-2009, 10:32 AM
Dealer : Gateway Toyota
1994 Toyota Camry,
2004 Toyota Sequoia
Last Online: Yesterday 10:01 AM
Andy4 is on a distinguished road.
Andy4's Photo Albums
has anyone tried sizing the polyurethane bushing for the rear sway bar?
energysuspension.com lists individual pieces by size.
