Old 05-15-2009, 09:41 PM
Dealer : Don Davis Toyota
2004 Toyota Sequoia,
- Other - 06 BMW 325i, 97 M3
Last Online: 10-27-2009 07:49 PM
DocPain is on a distinguished road.
DocPain's Photo Albums
Default Going on a long Expedition...what to do prior leaving.
Well, gang its time for a long family trip.
My 04 Sequoia is 2WD has about 73K on it right now. We plan on going down South Texas and across into Mexico border.
I will replaced all four tires this tomorrow. I've change the serpentine belt last July. Brakes and rotors brand new. Will do oil change 5-30W Synthetic blend(Valvoline) with OEM filter.
Should I change the rear diff yet? what about the front? My 04 is a 2wd, how do I know if it has LSD?...no not for smoking, lol.
Should I do coolant flush or bring it to the dealer? Anyone put RedLine water wetter in their radiator? does it cause water pump leak?
What else, let me know.
thanks
Old 05-15-2009, 09:49 PM
yspert's Avatar
Dealer : Rice Toyota
Last Online: 10-30-2009 10:49 PM
yspert is on a distinguished road.
yspert's Photo Albums
Exclamation Re: Going on a long Expedition...what to do prior leaving.
if you have a 2wd, then i wouldn't worry about the front diff.
stay away from the voodoo chemicals. keep each system's fluid clean
and you won't need the chemicals. yspert
Graduated from Y to Z status.
Old 05-16-2009, 09:25 AM
Default Re: Going on a long Expedition...what to do prior leaving.
yeah, the Redline cause leaking waterpump when I've used on my BMWs, twice!
Since it will be hot, I just don't want to stress the car that much.
Old 05-16-2009, 11:03 PM
JBK23's Avatar
Dealer : Lowe Toyota of Warner Robins
2006 Toyota Tundra SR5 DC
Last Online: Yesterday 11:15 PM
Images: 10
JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor.
JBK23's Photo Albums
Make sure the coolant is good check all fluids to be filled to proper levels be sure not to over
fill them.Make sure all of your lights, and signalswork make sure the A/C works too you know check that it blows cold would not want to leave with out that make sure the spare tire is good to go also.Another is make sure you have a good battery if you have to replace it try an optima you cant go wrong with them other than that you should be good to go. Have a nice trip !
2006 Tundra Double cab SR5 4x2 4.7L V8
Old 05-17-2009, 01:28 PM
Thanks guys!
I've just crawl under the car, damn, it does not have the front differential. All that I saw as the drive shaft exit from the tranny.
I found some cheap Synthetic Diff/gear oil from WalMart . They have two quart of 75-90 and two of 75-140. Should I just get it and mix them for the rear differential?
New Tires are in. New air filter and fresh Valvoline Synthetic blend.
Old 05-17-2009, 05:43 PM
JBH1989's Avatar
Dealer : Toyota of Santa Maria
- Other - 1991 Isuzu Trooper,
1999 Toyota Camry Tan w/ 1MZ-FE,
- Other -- 1993 BMW 525i
Last Online: 10-17-2009 04:39 PM
JBH1989 is on a distinguished road.
JBH1989's Photo Albums
Of course it doesn't have a front differential, front driveshaft, or transfer case--it's a 2WD!
Don't mix the fluids, go to a REAL store and get the right fluid for it. If you haven't had any battery problems, don't bother with a new one. Get an Interstate or ACDelco if you have to.
2004 Marlin Blue Pearl Sequoia SR5 2WD; 60k miles
1991 Isuzu Trooper 2.6L 5spd 4x4; 103k miles
1993 BMW 525i M50TUB25 auto; 286,500 miles
ASE Certified Brakes Technician / Automotive Electrical Specialist
Independent BMW Technician
Old 05-17-2009, 06:41 PM
lol!!! I figured that. I was thought I was going nuts!
Old 05-25-2009, 07:04 PM
Just got back. South Padre Island in TX was beautiful. We drove into Mexico, Metamoros, it was a big town. Fun, but the Swine thing still freaks me out. I ran 10 hours non-stop except for one time gas. It ran at least 21 mpg, wow!
My oil dip slight, very tiny amount. Coolant level stay even and the new tires did wonder. I might do Florida on the 4th.
