Go Back   Tundra Solutions Forum > SUV Forums > 1Gen-Sequoia
Old 05-31-2009, 11:36 AM
Last Online: 06-05-2009 10:39 PM
1scott is on a distinguished road.
1scott's Photo Albums
Default Sequoia Timing Belt/leather seats
I have a 2003 Toyota Sequoia that my Wife loves and has put 92000mi on it and it has been very trouble free. I read the owners manual and under normal conditions and I did not see a timinig belt replacement interval. I have never replaced the drive belt and from what I can see it still looks good, no cracks or noises or anything. Is their a way to check these new style belts for for wear like the old style v-belts which wore out fast but you could tell by how thin and low in the pulley they got?
The only problems we had with this car is brakes, which since we replaced all new rotors and heavy duty ceramic pads, front and rear, have lasted over 40kmi but they make noise when first backing out garage in morning. The other problem I have had is the leather seats have taken on some heavy wear and tear. I clean them and it seams like the dye comes off with the soap and water, they just get worse and worse. Have any of you found the leather dye/paint to be any good or easy to use?
Old 06-01-2009, 01:24 AM
Dealer : Toyota of Waldorf
2001 Toyota Sequoia
Last Online: 11-02-2009 06:05 PM
Limited Sequoia is on a distinguished road.
Send a message via AIM to Limited Sequoia Send a message via MSN to Limited Sequoia Send a message via Yahoo to Limited Sequoia Limited Sequoia's Photo Albums
Default Re: Sequoia Timing Belt/leather seats
Timing belt should be done at 90K at least that is what my 01 manual says.
Tommy
2001 Sequoia Limited Black
Old 06-01-2009, 08:10 PM
Sequoia311's Avatar
2003 Toyota Sequoia,
1997 Toyota Land Cruiser
Last Online: 06-02-2009 07:41 AM
Images: 12
Sequoia311 is on a distinguished road.
Sequoia311's Photo Albums
I've got an 03 Limited with almost 92000 miles now. I haven't had any problems with the leather, it looks like new. I had problems warping the front rotors while pulling my boat, so I switched to slotted rotors and Hawk pads, works great with no noise. Although, my belts are starting to squeal a little bit. I think its time to replace them.
Does anyone know if just tightening them would cause the squeal to go away? If so, is there a thread with some instructions??
Old 06-01-2009, 11:49 PM
integraGSR's Avatar
2005 Toyota Tundra
Last Online: 11-06-2009 11:58 PM
Images: 14
integraGSR will become famous soon enough.
Send a message via AIM to integraGSR integraGSR's Photo Albums My eBay
unable to tighten our belts. they are a tensioner style and it keeps a certain amount of tension on the belt. these tensioner do go weak and weaker as you put more and more miles on them. when replacing them, the PS pump needs to come loose, ALT needs to come completely off and then the tensioner can come off.
05 Salsa Red Pearl DC
01 Honda Civic
95 Acura Integra
Old 06-16-2009, 01:30 AM
Last Online: 10-20-2009 12:29 PM
tag3k is on a distinguished road.
tag3k's Photo Albums
1scott,
i recently purchased a '03 with 60k on it. i had the timing belt changed due to the fact the manual states that the belt should be changed every 90k or 6 years. i rather pay a little now for the peace of mind. my mechanic said that they usually go by mileage, but here in l.a. this is a low mileage car so i rather go by the years. also mechanic said that he would not suggest replacing the water pump since they tend to be expensive and they don't go bad too often. so i took his advice on that one and did not have it changed.
hope that this is helpful.
Old 06-20-2009, 07:30 PM
Last Online: 06-21-2009 02:35 PM
rbigs1157 is on a distinguished road.
rbigs1157's Photo Albums
Just took my 03 LTD into the shop with 89,000. WP had a small leak so had it replaced, Also replaced the timing belt since it's recommended at 90K and the plugs as well. Other than brakes and oil changes, this is the first "bigger" repair I've had although I've had similar problems as documented in other posts.
