Re: Tips on replacing door speakers?
Hey Daryl, speaker installation is a breeze but you need to make sure you get the right components, wire harnesses, tools, and go slow! THere is a special tool that will help with the retaining clips. The tool can be squeezed between the door frame and the panel, and then gently pryed so the clip pops out. Also you can turn the tool around and pry off your window handle if you have one. Once you have the panel off, you unscrew the old speaker and slip off the old wiring harness. Purchase wiring harness adapters from Crutchfield.com so this way you do not cut your factory wiring. These harnesses make it a very simple job and you don't risk screwing something up. Attach the new speaker, screw it in and pop your door panel back on.
The important thing to know is how many screws and clips each door panel has. DO NOT pull on your door panel too hard if you do not know for sure there are no screws or other wires still connected. You can easily break your panel or rip out the wiring for your automatic windows.
Crutchfield.com has a great customer support section, and if you order from them, they may even throw in an installation guide for your car making it very easy. Those guys are pros so check out the site.
Hope this helps!
