Old 08-03-2009, 08:30 PM
Last Online: 08-08-2009 09:29 AM
clearwaterpalms is on a distinguished road.
clearwaterpalms's Photo Albums
Default Clicking noise in dash board when I acclerate
Does anyone know or have had the same issue with a clicking noise behind the dashboard when you accelerate? It runs fine but I am curious about the clicking noise.
Old 08-06-2009, 09:26 AM
msk msk is offline
Last Online: 08-24-2009 01:31 PM
msk is on a distinguished road.
msk's Photo Albums
Default Re: Clicking noise in dash board when I acclerate
If the clicking happens at 25-35mph and only once after startup it is normal. I believe it is the ABS or VSC relay. They are loud but only happens once each time you drive the vehicle. You can search "clicking behind climate control" here and get more posts.
Hope this helps.
Mark
Old 08-06-2009, 12:59 PM
Dealer : Kings Toyota
2001 Toyota Sequoia
Last Online: 10-21-2009 08:20 AM
guyaverage is on a distinguished road.
guyaverage's Photo Albums
There is a ground wire on the firewall on the passenger side. Unbolt it and secure it to the engine somewhere then go for a drive and see if the ticking goes away. If that takes care of it, you can extend the wire a few inches and connect it somewhere else, or just eliminate it. Its a redundant ground wire that connects to the back of the engine. I drove without it for a while with no ill effects at all. Later after doing some other maintenance I extended the wire and connected it over by the airbox.
