Old 08-13-2009, 10:40 AM
Dealer : Toyota of Glendale
2006 Toyota Sequoia
Last Online: 11-19-2009 10:31 AM
wyun is on a distinguished road.
wyun's Photo Albums
Default 06 Sequoia - 100k - Any recommend services
I reached 100k on my 06 sequoia 2wd. At the 90k I've done the timing and fan belt, did major services, replaced the differential fluid, replaced plugs, and coolant. Did not replace water pump,pulleys, or seals tech said they were fine. I'm planning to keep sequoia until it stops running.
Should I go to synthetic oil, all oil changes used were regular oil, I've readed this formum about problems when going to synthetic
Service rep recommended at 100k - replacing/flush tranny (even though tranny is WS) and having values adjusted. Not sure if these are necessary.
Is there something I might be missing that I should replace to keep sequoia running?
Any problems you have seen after hitting 100k.
Old 08-14-2009, 02:49 PM
Sanchez's Avatar
2001 Toyota Sequoia,
2007 Toyota Camry,
- Other - Riding in Style
Last Online: 11-17-2009 11:57 AM
Sanchez is on a distinguished road.
Sanchez's Photo Albums
Default Re: 06 Sequoia - 100k - Any recommend services
you said the Tranny is WS.... what is "WS"?
How long ago did you change out the brake fluid or Power Steering Fluid?
Do you have a clean Air Filter?
When I hit 100k I did these items, not all of them are needed just because of 100k, it was just some things I wanted to do and some were needing attention too.
Did them at 100k so I could remember when they were done.
New Battery
Spark Plugs
Air Filter
Oil Change
Transmission FLush
Drain and add new Brake Fluid
Front Brakes/ Rotors Trued
Diff Oil Change
New Power Steering Fluid
Replaced steerng rack busings
Alignment
2001 Sequoia 2WD SR5
Mods:20s wrapped w/ 295/45/20
Borla Dual Side Exit Cat Back Exhaust
JBA Headers
OEM Foglights Install
TRD Drop-In Filter
Old 08-24-2009, 01:17 AM
Dealer : Kendall Toyota Scion
2004 Toyota Tundra
Last Online: 10-30-2009 10:06 PM
muvico is on a distinguished road.
muvico's Photo Albums
rear diff fluid change, if 4wd ,front diff oil change .New rotors if front vibration.spark plugs and fuel filter also could be replaced.other than that , sensors when engine light goes on.
