Re: Shocks
Levelling may be difficult.
The front and rear springs compress differently.
The front load is close to being constantly the same, and the rear load varies all the time ( with passenger weight, fuel, or towing), thus the rear height is rotating on the front hubs.
Raising the front to what appears to be level will impact your headlight alignment.
The shock numbers at tirerack site for the front of the tundra and the sequoia appear to be the same, so I would think the 5100 listed for the tundra should fit a sequoia.
Since the 5100 is height adjustable, get all your measurements on the existing shock/spring assembly under loaded conditions before removing and after they are removed. These may be needed to set up the 5100s
I've read on the site that more then a couple inches in height starts effecting the CV joint angle and wear on 4 wd models.
