Re: What torx T size to remove bolt from assist handle
Mine is out and about right now so I can't look and tell you, but there is no T28 or T29.
I'll check it out later, but either the 30 or the 27 should fit. Torx bits never seem to fit really tight with the bolt heads, there's always a little slop. You might get the T30 close and tap it with a hammer--I've stripped out my share of T30 bolts using a T27 because the 30 didn't seem to fit on the throttle bodies of BMW V8s.
2004 Marlin Blue Pearl Sequoia SR5 2WD; 60k miles
1991 Isuzu Trooper 2.6L 5spd 4x4; 103k miles
1993 BMW 525i M50TUB25 auto; 286,500 miles
ASE Certified Brakes Technician / Automotive Electrical Specialist
Independent BMW Technician
