Originally Posted by PagalDesi4Life
Since I want to keep the current scheme, are the original ip bulbs white with a plastic color film placed above them to project the various colors or are there actually different colored bulbs for each section?
How do you rate the difficulty of replacing these bulbs? How do you remove the instrument panel itself?
Question #1 - Yes they are amber color bulbs with a green cover (condom) over them. I pulled them off and put it back together and was not impressed with the color.
Question #2 - I would say 4/10 on difficulty. I have taken apart the dash probably 10 times and can do it in less than 5 minutes now.
I will do my best to explain, but its hard without me looking at it.
*take a picture of the ip while seq is running just in case the needles get bumped. Some tundra people had to do this, I have not seen a seq person having a problem with it
**I did not have a problem with it because they just went back to normal place
Lower your steering wheel all the way down
Unscrew the trim around the ip. I believe there are two screws just above the display
Pull the trim out completley (plastic oval piece the makes trims the ip)
Takes a little bit of manuvering because it is awkward, but you can get it
Unscrew the 4 screws (2 on top/2 on bottom) of the ip
Pull out the ip should have 3 cords hooked in to the back
I unplugged each cord so I could get the ip all the way out to work
Unscrew the plastic piece on the back
IP bulbs are there
Just turn the back of the bulb and you can get every bulb out
Takes a little bit of jiggling to get them back in because the bulb is a hair bigger
I def reccomend this. The first time I did it I was slow moving cause nobody had done a seq write up on it. I could now change a bulb in 10 min easy. If you have any questions let me know. It is a very easy project and just requires a little bit of patience and jiggling to get stuff out. Good luck and have fun!
