2002 Sequoia squeaking rear brakes
I have a 2002 Limited Sequoia, perfect shape 75 K miles. New brakes front and rear. I can't get the rear disc brakes to stop squealing when truck backs out of driveway in morning. New rear disc pads (semi metallic), anti squeal on pads, turned rotors which are way over the min thickness.
Does the e-brake rear brake shoes cause this squeal? If so, how far should I ajust star-washer on e-brake? E brake seems to work fine, pads are not worn at all and surface they touch inside rotor look very normal with little to no dust. If you adjust e brake drum brake pads too far out, you cant get rotor back on to mount brake caliper.
Anyone's advice appreciated.
