Old 10-12-2009, 12:01 PM
Dealer : Sandy Springs Toyota Scion
2004 Toyota 4Runner,
2002 Toyota Tacoma 4x4 xtrcab,
2000 Toyota Corolla,
1995 Toyota Supra 94 TT
Last Online: 10-12-2009 09:03 PM
ttman is on a distinguished road.
ttman's Photo Albums
Default is it OK to use 2 different tire sizes?
my front wheels are worn. I was wondering if I can get 265/70/17 and stick them in the rear & move the rear wheels to front. eventually I want to goto 265/70/17 all around (stock is 265/65/17), but don't have the $ to do it all at once, and my rears are still good.
2wd 2006 sequoia
Old 10-12-2009, 07:37 PM
big-o's Avatar
Dealer : Mark Miller Toyota
2002 Toyota Sequoia Limited
Last Online: 11-17-2009 10:32 PM
Images: 5
big-o is on a distinguished road.
big-o's Photo Albums
Default Re: is it OK to use 2 different tire sizes?
Generally not a good idea. Could vary with manufacturer, but I'm guessing they might not be close to the same height. Since your Sequoia is 2wd, you would probably be fine as long as the matching tires are on the same axle. Which sound like thats what your wanting to do. If it were 4wd, I wouldn't do it.
Old 10-13-2009, 12:12 PM
Greggcellent's Avatar
Dealer : Germain Toyota of Columbus
2004 Toyota Sequoia Ltd ,White/Charcoal
Last Online: 11-19-2009 12:04 PM
Greggcellent is on a distinguished road.
Greggcellent's Photo Albums
I would say your safe as long as you keep the same size on each axle . If you were driving a 4WD I would advise against it . And if your using different manufacture or type of tires your going to get different handleing and manuvering charactures which could be somewhat unsafe . Here is a tire size calculator you can run to see the size differences .
Tire size calculator.
04 Sequoia Ltd. Natural White / Charcoal , Pioneer Head Unit , Dome Lgt. Mod , Footwell Lgt. Mod , Armrest Mod ,
Old 10-13-2009, 12:24 PM
Dealer : Gateway Toyota
1994 Toyota Camry,
2004 Toyota Sequoia
Last Online: 11-14-2009 04:43 PM
Andy4 is on a distinguished road.
Andy4's Photo Albums
The different size tires may be picked up by the ABS and VSC systems, causing them to react.
The allowable difference may be less then the normal tread height (3/8") before systems kick in.
Old 10-17-2009, 04:27 PM
JBH1989's Avatar
Dealer : Toyota of Santa Maria
2004 Toyota Sequoia,
- Other - 1991 Isuzu Trooper,
1999 Toyota Camry Tan w/ 1MZ-FE,
- Other -- 1993 BMW 525i
Last Online: 10-17-2009 04:39 PM
JBH1989 is on a distinguished road.
JBH1989's Photo Albums
Since the 70% tires measure a good 1" greater in diameter and around 3" greater in circumference, you can't mix tires. The computers would go nuts. Considering the propensity for VSC instability in these trucks, it makes the idea even worse. The spare tire is full-size for a reason.
2004 Marlin Blue Pearl Sequoia SR5 2WD; 60k miles
1991 Isuzu Trooper 2.6L 5spd 4x4; 103k miles
1993 BMW 525i M50TUB25 auto; 286,500 miles
ASE Certified Brakes Technician / Automotive Electrical Specialist
Independent BMW Technician
Old 10-18-2009, 11:02 AM
big-o's Avatar
Images: 5
I guess what we need to know is if his 2WD Sequoia has the VSC? I wouldn't think it would, but if it does the above mention of VSC computer not liking it might apply.
