Old 10-19-2009, 07:39 PM
Dealer : Elk Grove Toyota Scion
2006 Toyota Sequoia
Last Online: 10-19-2009 07:39 PM
silversurfer01 is on a distinguished road.
silversurfer01's Photo Albums
Default Car Vibrating at 70+ miles
Recently, got some new tires on the stock rim (06 Sequioa SR5). Less than 10,000 on new tires. Now when driving above 70 miles per hour, the entire car shakes/vibrates. The steering wheel, the front seats, the seats in the back. It's like someone is shaking the car literary. When looking back at the passenger in the rear, you can see their heads shaking.
Any ideas? Bad tires? Got the tires from Toyota dealer where we bought the car.
Old 10-19-2009, 08:17 PM
netrickyaz's Avatar
05' Tundra (Tun-Tun)
Dealer : Desert Toyota Scion Of Tucson
2005 Toyota Tundra
Last Online: Yesterday 11:02 PM
Images: 112
netrickyaz will become famous soon enough. netrickyaz will become famous soon enough.
Send a message via AIM to netrickyaz netrickyaz's Photo Albums My eBay
Default Re: Car Vibrating at 70+ miles
which tires? i know someones taco that does this and i think its bad tires/tire
2005 Toyota Tundra Blue Steel Metallic (SR5® Access 4.7L i-Force V8 with VVT-i)
(K&N 77 Series Intake, ScanGauge II, Nokya Yellow Fogs (as DRL), Black Headlights, Tinted Side Markers, BSP Logos, Black Side Molding, Black Billet Grille, Red V8 Grill Logo, Custom Black "TRD Off Road" Graphics, Custom V8 side fender logos, 6000K HID Headlights (Halogen High Beam) Kenwood Deck, Infinity Speakers, Alpine 5-Channel Amp, 12" Infinity Sub(Custom Box)
(Future: Magnaflow 22" Single-Dual Exhaust, Electric Fan Conversion, Infinity Mono Amp For Extra Sub Power, Rims and Tires (17"))
Michael Jackson (08/29/1958 - 06/25/2009)
Old 10-20-2009, 12:24 PM
Dealer : Gateway Toyota
1994 Toyota Camry,
2004 Toyota Sequoia
Last Online: 11-22-2009 10:01 AM
Andy4 is on a distinguished road.
Andy4's Photo Albums
Look at the tires for any irregular wear.
Check the rims for a thrown balancing weight.
Check the back/inside of the rims for mud or something that could be throwing the balance off.
There is a slight chance when the tires were filled with air that enought condensation water was blown in to the tire that at high speeds it throws the balance off.
Check the tires for something being in the tread, such as tar, putty, etc, that can throw the balance off.
The drive shafts have balancing weights attached that could have come off.
The front CV shafts (4WD) on some vehicles have harmonic balance that slide along the axle. If it moved it can now be off balance.
Just a few things to look at..........
Old 10-23-2009, 09:51 PM
big-o's Avatar
Dealer : Mark Miller Toyota
2002 Toyota Sequoia Limited
Last Online: Yesterday 10:25 PM
Images: 5
big-o is on a distinguished road.
big-o's Photo Albums
Typically these heavy Sequoia's can be hard on front tires. Especially if you have a lift in the front, and the alignment has a little too much positive camber. I would make sure you rotate your tires every 3000 miles, or when you first sense the vibration. I did the poly bushings on the sway bar, and steering rack and it still wanted to eat the front tires on the outer edge. I noticed this much more when I was running a mud tire, but it still does it with a all terrain.
Old 11-10-2009, 12:11 PM
Dealer : Thompson's Toyota of Placerville
2006 Toyota Sequoia,
2007 Toyota Corolla
Last Online: 11-23-2009 03:46 PM
parrot head is on a distinguished road.
parrot head's Photo Albums
balance the tires
