Old 10-20-2009, 09:15 PM
Dealer : Gene Messer Toyota
2002 Toyota Sequoia
Last Online: 11-28-2009 08:17 AM
flyingyahoo may have some regrets.
flyingyahoo's Photo Albums
Default Timing Belt replacement parts
I am going to be replacing the timing belt on a 2002 Sequoia. I was wandering while I am at it what else do I need to replace? So far my list is:
1. Timing belt
2. Tensioner
3. Water pump
4. Water pump gasket
5. T-stat (Maybe)
6. T-stat gasket
7. Serpentine belt (Maybe)
8. Radiator Hoses
Is there any thing else I should replace?
I keep seeing references to an idler pully. Is this the same as the tensioner pully per this illustration? https://www.1sttoyotaparts.com/partscat.html. If so do I need both te right and left pully?
I have also purchased the FSM but they have not arrived. Thanks for all of the help.
Old 10-21-2009, 07:11 AM
Dealer : Kings Toyota
2001 Toyota Sequoia
Last Online: 01-14-2010 07:59 AM
guyaverage may have some regrets.
guyaverage's Photo Albums
Default Re: Timing Belt replacement parts
Yes, I would recommend replacing both the idler pulley and the tensioner pulley (in addition to the tensioner itself). It will add a few dollars to your overall costs but well worth it. I was surprised at how much play was in each pulley when I removed mine at 96k miles. Had I known they were this loose (compared to the new ones) I would have done this job a lot sooner than I did.
Some people also replace the crank oil seal and both camshaft oil seals while everything is exposed. If we still have our '01 at 180k miles I will change them, but at 90k miles I dont find it necessary.
Also I didnt see on your list the two o-rings that are necessary for the water pump. I dont have the part numbers here but if you search some of the timing belt threads some people have the part numbers listed.
Old 10-21-2009, 08:11 AM
Last Online: 10-21-2009 03:53 PM
MightyAl may have some regrets.
MightyAl's Photo Albums
I have worked on a lot of toyos and if the crank seal and cam seals are not leaking then I leave them alone. I agree the you should do both the timing belt tensioner and the serpentine tensioner. The timing belt tensioner is usually what causes timing belt failure and not the timing belt itself.
Old 10-21-2009, 11:04 AM
2002 Toyota Sequoia
Thanks for the response. Exactly what I was looking for.
Old 10-21-2009, 11:14 AM
Sparks Toyota-TRD's Avatar
Preferred Dealer
Last Online: Today 04:28 PM
Sparks Toyota-TRD is on a distinguished road. Sparks Toyota-TRD is on a distinguished road.
Sparks Toyota-TRD's Photo Albums
We are getting so many requests for these 4.7 timing change parts its crazy! By the way I would change the maybe to just a yes on the t-stat and belt. Your taking everything off to get to there anyway you might as well replace them unless you have done it recently already.
Jamie
TRDSPARKS.COM TRD Performance Parts and Accessories at Discounted Prices!
Toll Free#1-866-249-3607
WILL TRD / AFTERMARKET PARTS VOID MY WARRANTY? NO -->> http://www.trdsparks.com/warrant_aft..._products.html
Old 10-27-2009, 08:00 AM
Dealer : Toyota of Naperville
2001 Toyota Sequoia
Last Online: 03-14-2010 08:47 PM
Heaterswa may have some regrets.
Heaterswa's Photo Albums
Is there a list with part numbers for this job? Where is the best place to buy these from on-line?
-Bryan
Old 10-27-2009, 06:40 PM
Dealer : Don Davis Toyota
2004 Toyota Sequoia,
- Other - 06 BMW 325i, 97 M3
Last Online: 02-08-2010 07:06 PM
DocPain may have some regrets.
DocPain's Photo Albums
I'm going through the same thing, need T belt replacement soon. My 04 getting 87K already, we are ready to go on a ski trip in December. I have email Shannon at Champion Toyota for asking the dealer's mechanic. They have their software with all the parts and number listed for each job.
BTW...order from them, It is a fraction of what we have to paid at the dealership or other outside stores.
Old 10-28-2009, 08:55 AM
Preferred Dealer
Here is a list of what most people are purchasing. You can add or delete what you want as needed. Included is our price, Retail pricing is about 25% higher than what I have shown below.
96761-35035 Ring $2.66
90311-38065 Seal $11.94
90311-A0001 Seal $7.37
96761-24019 Ring $2.47
16100-59275-83 Water Pump $107.30
90916-A2003 Belt $33.69
13568-09070 Belt $39.25
90916-03100 Thermostat $14.24
16346-50010 Thermostat Gasket $3.24
13503-0F010 Idler $66.62
13505-0F010 Idler $66.34
16620-0W101 Tensioner $59.66
16572-0F010 Radiator Hose $18.52
16571-0F030 Radiator Hose $12.03
This is based on per vehicle, but you get the idea of cost and what you need from that list.
Thanks,
Jamie
