Zero Point Calibration step by step help
+ Reply to Thread
Results 1 to 6 of 6
Thread: Zero Point Calibration step by step help
  1. #1
    Join Date
    Jan 2005
    Location
    New York, NY
    Posts
    42
    Liked
    0 times
    Thanks
    0
    Rep Power
    15
    Default Zero Point Calibration step by step help
    replaced the steering rack on a 01 sequoia 4wd, then got the alignment done, I cant seem to re calibrate the steering/yaw sensor points. I followed several different directions posted on this board and other, with no luck, the VSC, TRAC lights are still on, no CEL, no obd2 codes.
    Can anyone confirm a procedure that doesnt require the Toyota SST computer and works?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Jan 2005
    Location
    New York, NY
    Posts
    42
    Liked
    0 times
    Thanks
    0
    Rep Power
    15
    Thread Starter
    Default Re: Zero Point Calibration step by step help
    bump to the top
  4. #3
    Junior Member spinn's Avatar
    Join Date
    Oct 2006
    Location
    SF Bay Area
    Posts
    217
    Liked
    3 times
    Thanks
    0
    Images
    4
    Rep Power
    10
    check your mail.
  5. #4
    Join Date
    Jan 2005
    Location
    New York, NY
    Posts
    42
    Liked
    0 times
    Thanks
    0
    Rep Power
    15
    Thread Starter
    Thanks Spinn for trying to help.
    It looks like the sequoia / tundra , requires the SST to complete the procedure. Going to bring it to my local indie, tech said he can do it through the Snapon MB unit..
    Heres the last resort, its a little different than the FSM extract. Also, hw do you turn the key to OFF (LOCK?) with the gear selector not in P? or do they mean ACC and not off?
    Put the transmission in Park, and turn the ignition ON.
    Using a jumper wire, short terminals Ts and CG on the DLC3 diagnostic connector four times or more within eight seconds. This will erase the recorded zero point.
    Turn the ignition to OFF and remove the jumper wire.
    Make sure the steering wheel is centered, and turn the ignition switch back ON.
    The stability control warning light will come on, then go off after about 15 seconds.
    Wait at least two seconds after the light goes off, then turn the ignition back OFF.
    Use the jumper wire to reconnect terminals Ts and CG on the DLC3 connector, and turn the ignition back ON.
    The traction control warning light should come back on and start to flash after about four seconds. The zero point has been reset. The ignition switch can now be turned OFF and the jumper wire removed.
  6. #5
    Join Date
    Oct 2006
    Location
    SF Bay Area
    Posts
    217
    Liked
    3 times
    Thanks
    0
    Images
    4
    Rep Power
    10
    Are you goin' to try that last method out first? I assume once it's reset, the lights will turn off? Hoping that works...
  7. #6
    Join Date
    Jan 2005
    Location
    New York, NY
    Posts
    42
    Liked
    0 times
    Thanks
    0
    Rep Power
    15
    Thread Starter
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
