2003 Sequoia Transponder Key ECU location and removal?
+ Reply to Thread
Results 1 to 5 of 5
Thread: 2003 Sequoia Transponder Key ECU location and removal?
  1. #1
    Join Date
    Jan 2007
    Location
    Oceanside, CA
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Exclamation 2003 Sequoia Transponder Key ECU location and removal?
    When I purchased my used 2003 Sequoia LTD, it came with only one set of master key + remote and I just lost it. I then purchased a new blank transponder key ($60) w/o the programming and had it cut based on my VIN# by the dealer just to be able to put the car into neutral position and get it towed to the local dealer.
    Local Toyota dealer said b/c of my specific 2003 year model, they cannot reseed the ECU and a new Transponder ECU is required ($350 ECU + $60 key + $220 labor) to program a new key. If it was 01-02 year model, the ECU reseeding would cost $200 labor + $60 key. Hefty price tag for just a simple key!!!
    I read somewhere that some locksmiths services offer to reset/reflash/reprogram the existing ECU for $150-$250 with new pair of keys. Could anyone confirm if this procedure can apply to a Sequoia 2003 year model?
    That being said, if I decide to go that route, I also don't know where the ECU module is located in my car to remove and ship it to the locksmith service either. Appreciate very much if anyone could enlighten me on the ECU location and removal procedure.
    Thanks a bunch...
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Nov 2006
    Location
    Western PA
    Posts
    77
    Liked
    0 times
    Rep Power
    9
    Default Re: 2003 Sequoia Transponder Key ECU location and removal?
    You can find directions to reprogram here. All you need is the new key.
    Free Keyless Remote Fob Entry programming instructions, procedures for all automotive vehicles
    I guess you don't have the key or remote, so I don't know if this is any help, but it may be of future use to you.
    Attached Files Attached Files
  4. #3
    Join Date
    Jan 2007
    Location
    Oceanside, CA
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks Jim:
    The instructions will definitely serve me later once I get the 1st key reprogrammed with the reflashed ECU.
    I noticed that the attached ECU immobilizer diagram is for a 2005 Sequoia and wonder whether it would apply to a 2003-04 model too?
  5. #4
    Join Date
    Nov 2006
    Location
    Western PA
    Posts
    77
    Liked
    0 times
    Rep Power
    9
    Don't know for sure, but why would they move parts around with almost no change in the interior design?
  6. #5
    Join Date
    May 2010
    Location
    Huntington Beach, CA
    Posts
    24
    Liked
    0 times
    Rep Power
    6
    Quote Originally Posted by Jim Ford View Post
    They changed some of the electronics starting in 2003.
    I remember when researching my options for the 2002 that there were a couple of posts that discuss the locksmith option... here's one thread that should be helpful: Extra key needed for 05 Sequoia!
    Once you get the key programmed, I think you'd be set to program your own extras and the remote.
    Some careful shopping on eBay helped me (well, helped me help my girl friend and her 2002, actually)...
    I got Toyota-branded transponder keys for like $13 from seller carkeysolution, and my local locksmith cut them for like two bucks each.
    And I got a brand new wireless remote from seller keys_star (he sells both used and new remotes, but I splurged for a new one initially). Later I also found a very good used remote that looked like new and at a good price (must look at the photos and descriptions carefully or ask to see a photo of the actual remote). The number on the back of the remote can be helpful to verify you're buying the right spare.
    The year of your Sequoia is important to know to purchase the proper chip key blank as well as the proper wireless remote -- they both can vary by year. And of course the programming procedure varies.
    1994 Camry V6 XLE - Cashmere Beige
    2002 Sequoia - White
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Tags for this Thread
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
