Noise from transfer case - '02 Sequoia
+ Reply to Thread
Results 1 to 3 of 3
Thread: Noise from transfer case - '02 Sequoia
  1. #1
    Rookie maggioli is on a distinguished road.
    Join Date
    Sep 2010
    Location
    buffalo, ny
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Angry Noise from transfer case - '02 Sequoia
    I had some vibration and noise coming from the front of my '02 Serquoia which has 106,000 miles on it. I just brought it into the dealer and their diagnosis was "noise form transfer case, vehicle slips in and out of 4WD, component broken inside transfer". They told me that it was not worth repairing, but quoted me $4,000 to try to fix. But also said that they could not guarantee it. They recommend that I just drive it until it dies. Any thoughts?
    Thanks in advance.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Jim Ford is on the right track.
    Join Date
    Nov 2006
    Location
    Western PA
    Posts
    75
    Liked
    0 times
    Rep Power
    7
    Default Re: Noise from transfer case - '02 Sequoia
    Try here, and install yourself or have local mechanic do it for you. Not a lot of labor involved. Before you do anything - get a second opinion.
    Car-Part.com--Used Auto Parts Market
  4. #3
    Veteran Member big-o has much to be proud of. big-o has much to be proud of. big-o has much to be proud of. big-o has much to be proud of. big-o has much to be proud of. big-o has much to be proud of. big-o has much to be proud of. big-o has much to be proud of. big-o has much to be proud of. big-o has much to be proud of. big-o has much to be proud of. big-o's Avatar
    Join Date
    Feb 2002
    Location
    Point of the Mountain, UT
    Posts
    1,043
    Liked
    1 times
    Images
    14
    Rep Power
    55
    $4000 to replace a transfer case?? That is crazy!! They told you to drive it till it dies?? What is the point of having 4WD if it doesn't work....that dealer is wacked! I agree with Jim Ford....and have a second opinion for sure. Have the fluid drained and checked for debris. If it's bad, pick up a used one from a local wrecking yard and have a trustworthy 4WD shop install it for you.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
