Question Fasten Seatbelt Light keeps FLASHING!
+ Reply to Thread
Results 1 to 11 of 11
Thread: Fasten Seatbelt Light keeps FLASHING!
  1. #1
    Join Date
    Aug 2010
    Location
    Greensboro, NC
    Posts
    10
    Liked
    0 times
    Rep Power
    0
    Default Fasten Seatbelt Light keeps FLASHING!
    Hi guys......new Sequoia owner here!! Finally picked up a 2004 LTD 4WD!! Love it so far, but it has one annoying feature.......the "Fasten Seatbelt" light on the dash is intermittently flashing. (Yes, I have my seatbelt fastened, and both are fastened if I have a passenger!)
    Anyway, I can wiggle my seatbelt "receptacle" beside the seat where you click it in and it will stop temporarily. There has to be something loose, or maybe an electrical short????
    Anyone else had this experience? Not sure if this would cause any safety concerns or not.
    Thanks for any input!
    Here's a pic!!
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member big-o's Avatar
    Join Date
    Feb 2002
    Location
    Point of the Mountain, UT
    Posts
    1,041
    Liked
    5 times
    Images
    14
    Rep Power
    57
    Default Re: Fasten Seatbelt Light keeps FLASHING!
    Wow, looks nice! Not sure about the seatbelt light? Maybe a french fry got stuck in the receptacle?? Mine is kinda worn out, but the light portion is still working. Someone might have this issue and can chime in....Good luck!
  4. #3
    Join Date
    Aug 2010
    Location
    Greensboro, NC
    Posts
    10
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    LOL!! Not sure about the french fry...it looks like nobody ever ate in this truck!! It is almost like new!
    I need to find out how these things make a connection once you click the belt in......something has to be loose or contacts bent to not make a good connection.
  5. #4
    Join Date
    Jul 2005
    Location
    New England
    Posts
    1,133
    Liked
    369 times
    Images
    25
    Rep Power
    22806
    Quote Originally Posted by Bri-Guy View Post
    Here's a pic!!
    I had the same problem with my 2004 SR5 which I have owned since new.
    Did a little bit of research and it appears that the inner seat belt buckle contains a microswitch that senses when the seat belt tab is inserted.
    On the theory that the buckle or the microswitch has some dirt or debris in it, I decided to try cleaning the buckle/switch. I used MAF spray (any electronic cleaning spray would be fine, I think) and gave the buckle a couple of good long blasts through the tab opening in the top. I wrapped a cloth around the buckle first to catch the liquid solvent that ran out. And just to be clear, I did this with the buckle installed and connected - i.e. I did not remove it from the vehicle.
    And.....success! No more flashing seat belt light!
    As a backup, here's the part number should you need to replace the buckle - $23.84 from 1sttoyotaparts. The -B2 is a color code, so watch out for that. Also there's a different part number if you have a manual seat.
    Driver seat belt inner (Buckle, W/power seat, Charcoal Left) 73240-0C050-B2
  6. #5
    Join Date
    Feb 2002
    Location
    Posts
    1,041
    Liked
    5 times
    Images
    14
    Rep Power
    57
    Great solution! I'll have to try that on mine and see if the clicker part engages a little smoother.
  7. #6
    Join Date
    May 2010
    Location
    San Diego
    Posts
    41
    Liked
    1 times
    Rep Power
    5
    just unplug that harness and you won't have the light bothering you anymore. that's what i did.
  8. #7
    Join Date
    Aug 2010
    Location
    Greensboro, NC
    Posts
    10
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Mibro - Thanks for the reply! I have some contact cleaner, so I'll hook the belt to the buckle and give it a couple of shots. This light is annoying, so I hope it works!
    I looked up the part number you provided....was hoping there was a picture/explosion of the assembly, but no luck.
    Will let you know if it works!!
    Thanks again!!
  9. #8
    Join Date
    Jul 2005
    Location
    New England
    Posts
    1,133
    Liked
    369 times
    Images
    25
    Rep Power
    22806
    Thanks again!!
    Not so fast. Update....not a permanent fix. Seemed to work for a while but flashing seatbelt light has returned. Next step - remove and inspect the buckle assembly. If I don't find any problems - e.g. cut/broken wires - then I'll replace it.
  10. #9
    Join Date
    Aug 2010
    Location
    Greensboro, NC
    Posts
    10
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    OK......I tried spraying contact cleaner in the assembly......seemed to improve for a day or two, but it's back to flashing 75% of the time. Might see how hard it is to remove the buckle assembly. Let me know if there are any tips to remove it!
    Please keep updating!!
    Rookie Jonesw3's Avatar
    Join Date
    Apr 2011
    Location
    Auburn, Al
    Posts
    7
    Liked
    0 times
    Rep Power
    0
    I know this is an old post but I am having this issue now? Any updates on how to fix it?
    2004 Tundra DC 4x4 Mostly stock (for now)Maganflow Exhaust WAAG Brushguard Leer Camper shell with custom built roof rack BFG KOs more to come....
  12. #11
    Join Date
    Jul 2005
    Location
    New England
    Posts
    1,133
    Liked
    369 times
    Images
    25
    Rep Power
    22806
    Quote Originally Posted by Jonesw3 View Post
    Replace the driver inner seat belt assembly 73230-0C050-B2. B2 is the color code and may be different for your Sequoia.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
