Do I need to reset ECU or something?
+ Reply to Thread
Results 1 to 4 of 4
Thread: Do I need to reset ECU or something?
  1. #1
    Junior Member spinn's Avatar
    Join Date
    Oct 2006
    Location
    SF Bay Area
    Posts
    215
    Liked
    3 times
    Images
    4
    Rep Power
    10
    Default Do I need to reset ECU or something?
    A while back, I had noticed my mpg had taken a dive on 2001 SR5. I could've sworn I at some point or another (past 8 months) was getting about 18 mpg; I'm lucky to get 15 mpg now. One thing I had noticed was that a hose which vented gases from the gas tank and connected to the intake manifold, had popped off. Since reattaching it, I still seem to be getting less mpg than what I was getting before. Does the computer need some sort of reboot? What do I need to unplug? Any thoughts?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member big-o's Avatar
    Join Date
    Feb 2002
    Location
    Point of the Mountain, UT
    Posts
    1,041
    Liked
    5 times
    Images
    14
    Rep Power
    57
    Default Re: Do I need to reset ECU or something?
    Sorry, I have to ask....first question is: Do you do the fuel mpg reset each time you fill up with gas? If not, each time you need to hold the far left and far right button down for about 10 seconds until it goes back to 0-mpg. Also, do you only use that gauge...or do you do an actual calculation of miles traveled and fuel used...and add in any tire diameter changes? Also, does your fuel station use Ethanol in the mix? Do you always use the same brand and octane? Have to also ask if the air filter has been changed at normal intervals, or any other maintenance issues? Tire pressure?
  4. #3
    Join Date
    Oct 2006
    Location
    SF Bay Area
    Posts
    215
    Liked
    3 times
    Images
    4
    Rep Power
    10
    Thread Starter
    I always do the calculation myself based on miles driven between fill ups. On a recent long trip from SF to LA, I got about 16 mpg...switching between no o/d and o/d.
    Tire diameter is stock.
    It's possible Ethanol is in the mix, but I haven't noticed. Usually use Costco, Shell, or Valero 87 Octane.
    Air filter has not been changed since about 20K ago when the previous owner had it changed. I had done a visual not too long ago and it didn't look that dirty...maybe it actually is. Oil changed w/synthetic not too long ago.
    Have not checked tire pressure, but will do so later tonite.
  5. #4
    Join Date
    Feb 2002
    Location
    Posts
    1,041
    Liked
    5 times
    Images
    14
    Rep Power
    57
    Spinn, sounds like you're keeping a close eye on it. The hose that came off could have had something to do with it...possible loss of vacuum or something? Could have been under-powered during that time, and it could take a few hundred miles for the computer to relearn. Not sure that anything is wrong, and it could be a mixture of variables. Not sure about California, but our stations are mostly using Ethanol in the fuel, and economy suffered a little...can't find any stations without it now. I've also noticed that when it gets colder, the fuel economy goes down slightly...but that might have something to do with the air being more dense. I'm happy if it's above 16 mpg's. Cruise control seems to help me keep my foot out of it.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
