Old 12-18-2003, 02:58 PM
mcmatt's Avatar
Dealer : Classic Toyota Scion of Round Rock
2001 Toyota Sequoia
Last Online: 10-30-2009 11:36 PM
mcmatt is on a distinguished road.
mcmatt's Photo Albums
Default Steering
I noticed all the alignment discussion. I have a problem with pulling also even though alignment is good. My steering wheel is not centered. How can you center the steering wheel? The alignment shop said you can't, but that doesn't make sense.
Thanks for help
Old 12-18-2003, 03:58 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
1) Find a good independent shop with a Hunter alignment rack equiped with their CAMM console. Don't expect a dealership to do it to the specs below...they're within Toyota's spec, but much tighter. The alignment can be "good" within Toyota's too-broad spec, and the rig still doesn't drive like it should.
2) Have it aligned to these specs: DJ's Alignment Setting Recommendations
3) Centering the steering wheel is easily done during alignment by shortening the adjustment on one tie rod and equally lenthening the tie rod on the other side.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 12-18-2003, 04:18 PM
616269799's Avatar
Dealer : Toyota of Muskogee
2006 Toyota RAV4,
2005 Toyota Camry
Last Online: 10-31-2009 08:09 AM
616269799 is on a distinguished road.
616269799's Photo Albums
Thanks for help
Went through the exact same issue on my, "prior to Tundra" owned, Nissan Frontier. The dealership nor Nissan's factory rep could get the steering wheel straight. They continued to work on it over and over without success, several. Told Nissan to stick it and traded it for the Tundra. Couldn't be happier.
At least someone has taken the time to determine how to correct this issue on the Tundras.
Win or Lose, but Finish the Game
Old 12-18-2003, 08:13 PM
DJ DJ is offline
Dealer : Fowler Toyota
2001 Toyota Sequoia,
DJ will become famous soon enough. DJ will become famous soon enough.
DJ's Photo Albums
Ken is right, as usual.
Centering the steering wheel is a routine part of aligning any vehicle. The fact that it is not centered means the alignment is not correct. The fact that "the alignment shop" said it can't be centered means they are utterly incompetent.
Old 12-18-2003, 09:00 PM
mcmatt's Avatar
2001 Toyota Sequoia
Default more information on steering
Ken
Thanks Ken, that gives me confidence. Actually more had happened, but I didn't want to cloud my first request for info. I found that steering wheel centering procedure on ALLDATA DIY. I did it myself and got the steering wheel straight!! I knew I had jacked the alignment though so I took it back. The camber was way out and the toe was a little out. The SAI, however, was 20deg on the left wheel and 10.8 deg on the right. The right is in spec, but the left is out. The alignment shop got the camber,caster, and toe in spec. but they said they don't adjust the SAI. Do you think I am OK as far as tire wear goes. I am now happy with the "straightness" and the steering returnability. Thanks for info.
Old 12-18-2003, 10:28 PM
DJ DJ is offline
DJ's Photo Albums
Something's fishy.
SAI, which means "Steering Axis Inclination", is the INWARD lean of the steering axis. Caster is the REARWARD lean of the steering axis. Caster is independently adjustable, but SAI is not. Consider why.
Camber is the outward lean of the wheel. If you make the wheel lean MORE outward, thereby making camber more positive, you unavoidably make the steering axis lean LESS inward, thereby making SAI less positive. The point is that the SUM of camber and SAI stays constant. This sum is called the "Included Angle", and its value is fixed by the design of the spindle.
So, if camber is "in spec", then SAI is "in spec" also. Camber of about 0.25 degrees produces an SAI of about 10 degrees (I'm going by memory here).
What's fishy? How in blue blazes could SAI be 20 degrees on the left? It can't, but it CAN be measured incorrectly. I suspect it was, which means I would not trust ANY of your alignment measurements.
Old 12-18-2003, 11:02 PM
mcmatt's Avatar
2001 Toyota Sequoia
Default I agree
Originally Posted by DJ
Something's fishy.
Thank you very much for detailed information. I am an engineer and I really get tired of having to research and figure things out on my own from documents and resources such as yourself. I guess we don't pay the service industry enough to employee people that enjoy understanding details of their trade and fixing hard problems!!
I thought they may have measured it wrong because they weren't even paying attention to it and said the vehicle had to have the wheels lifted for it to be measured or some crap. Anyway, I will try to find a better alignment shop.
Thanks again.
Old 12-18-2003, 11:55 PM
mcmatt's Avatar
2001 Toyota Sequoia
Cool Reference Info
Here is some very detailed and interesting info I found. I think the SAI was measured wrong because I noticed the brakes have to be locked and I did not see them do that at all.
http://www.hunter.com/pub/undercar/2...teeringgeo.pdf
This one has an animation.
http://www.hunter.com/pub/undercar/except/anim003.htm
Camber
http://www.hunter.com/pub/undercar/except/anim001.htm
Caster
http://www.hunter.com/pub/undercar/except/anim002.htm
Toe
http://www.hunter.com/pub/undercar/except/anim004.htm
Old 12-19-2003, 10:17 AM
DJ DJ is offline
DJ's Photo Albums
Camber
Caster
Toe
You found the good stuff.
