**looking for OEM JBL speakers for Sequoia**
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: **looking for OEM JBL speakers for Sequoia**
  1. #1
    Join Date
    Feb 2012
    Location
    Missouri City
    Posts
    13
    Liked
    0 times
    Rep Power
    0
    Default **looking for OEM JBL speakers for Sequoia**
    I just bought a 05 Sequoia, and the front speakers are blown. If you have the OEM JBL speaker and you are not using them and willing to sell them please let me know. I do not want to pay $200+ from the dealership. I do not mind if they are used, just not another broken speaker. Please help if you can. thanks.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Jul 2011
    Location
    Knox
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Default Re: **looking for OEM JBL speakers for Sequoia**
    This may help you with a cheaper solution...
    Simply Speakers - Quality Parts and Service
  4. #3
    Junior Member SteveInCal's Avatar
    Join Date
    Dec 2008
    Location
    San Rafael, CA
    Posts
    140
    Liked
    8 times
    Rep Power
    7
    This may be slightly off topic, but I was convinced my speakers were blown because the sound distortion was pretty bad. However, the speakers looked fine once I pulled them out of the doors.
    Was your speaker damage obvious? I didn't check the tweeters in the top of the doors, has anyone seen damage in those?
    I'm starting to think my amp(s) are cooked, but don't know how to test them.
  5. #4
    Junior Member silverdouble's Avatar
    Join Date
    Jun 2004
    Location
    NJ
    Posts
    129
    Liked
    21 times
    Rep Power
    450
    I just went threw this with an 04 tundra double cab It has 86160-AF060 7" speaker. It was starting to to Buzz and I could not see any damage to the foam surround. I did a lot research and came up with using the 6 1/2" driver in the JBL GTO608C. The brackets that come with it fit with out a problem and it is 2 ohm driver just like the factory and amazon has them for $60.00.
  6. #5
    Join Date
    Oct 2006
    Location
    Humble, TX
    Posts
    11
    Liked
    0 times
    Rep Power
    0
    I have a 2006 Sequoia and want to replace the speakers in the front as well. Are the speakers separates or are they just a normal single speaker with a woofer and a tweeter in the middle. And are they 7" or 6.5"? Do i need to buy adapters to fit 6.5" speakers? eBay has the adapters for $9.99 a pair. And what are the sizes of the rear door speakers also? Thanks.
  7. #6
    Join Date
    Jun 2004
    Location
    NJ
    Posts
    129
    Liked
    21 times
    Rep Power
    450
    Quote Originally Posted by dmata10 View Post
    They are separates they come with a 6.5", tweeter and crossover. I just used the 6.5" speaker and the adapter that came with the speakers only other thing I needed was 8 1 3/4" screws to mount the speaker adapter to the stock mount. I took the factory female spade connectors out of the factory plug to hookup to the speaker so i didn't have to cut any wires. I didn't check the size of the rear doors but they are smaller than the fronts. While I had the door panels apart I repainted the grills since all mine had rust stains on them.
    Click image for larger version.
ID:	83884Click image for larger version.
  8. #7
    Veteran Member LSUMatt1514's Avatar
    Join Date
    Nov 2007
    Location
    Birmingham, AL
    Posts
    805
    Liked
    9 times
    Rep Power
    187
    Quote Originally Posted by silverdouble View Post
    This states that these drivers a 4 ohm...not 2 ohm drivers. Where did you find them with a 2 ohm driver? Thanks!
    2008 Tundra Crewmax Limited 4x4 5.7L V8 Slate Metallic
    OEM Navigation w/ Backup Camera, Sirius, Escort 8500 X50 Radar Detector, Lockpick 2AV, 700W Inverter, Alpine PKG-RSE2 RSES, BakFlip F1 Tonneau, Platinum Edition Grille, AFE Pro Dry Air Filter, Charcoal Filter Removed, TRD Sway Bar, TRD Sport Shift Knob, TRD Sport Pedals, TRD Badges, Woodgrain Interior, Toyota XSP Skid Plate, Toyota All Weather Mats, Chrome Exhaust Tip, Craven Speed Antenna, WeatherTech Side Deflectors and Sunroof Wind Deflector, Full V-LED Conversion, Line-X Bed Liner, Toyota Door Sill Protectors, Tinted Windows
  9. #8
    Join Date
    Nov 2007
    Location
    Birmingham, AL
    Posts
    805
    Liked
    9 times
    Rep Power
    187
    Never mind...I found it. Sorry about that...it has been a long day...
  10. #9
    Join Date
    Oct 2004
    Location
    Los Angeles, CA
    Posts
    30
    Liked
    0 times
    Rep Power
    11
    I made a video on how I installed the GTO608C into my 2002 Sequoia. The brackets do not fit and have to be modified. I was able to cut the old speakers bracket and connect it to the adapter to make a clean fit. http://http://youtu.be/NcagkMSbb1g
  11. #10
    Supporter SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    Earth
    Posts
    4,602
    Liked
    2168 times
    Images
    26
    Rep Power
    67158
    how do they sound? did you leave the mids and tweets hooked up? your link is broken.
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  12. #11
    Join Date
    Aug 2009
    Location
    Earth
    Posts
    4,602
    Liked
    2168 times
    Images
    26
    Rep Power
    67158
    Quote Originally Posted by LSUMatt1514 View Post
    These are 2 ohm GTO628 | Concert-quality 6 1/2 inch 2-way Car Speakers | JBL US
  13. #12
    Join Date
    Apr 2012
    Location
    Chandler
    Posts
    30
    Liked
    6 times
    Rep Power
    4
    Quote Originally Posted by SuckersWalk View Post
    The 628's are way cheaper on Amazon, $47 vs. $106. Has anyone used the 628? It is the same as the 608 but has a tweeter above the cone. Just curious.
    2005 Sequoia Limited 4WD
  14. #13
    Join Date
    Feb 2014
    Location
    United States
    Posts
    46
    Liked
    5 times
    Rep Power
    745
    My alternative to replacing the front speakers since mine were also blown was replacing ALL of my speakers and adding a sub and a pioneer HU, sad I did not do this earlier, altogether it ended up costing me 700, did the install myself and made speaker mounts with MDF.
    If you happen to have a little extra to spend and are looking to keep the car for a couple more years I would say that you should go with this alternative, the sound difference is unbelievable!!!
    Sent from AutoGuide.com Free App
  15. #14
    Join Date
    Apr 2014
    Location
    Texas
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    I just did this Simply Speakers refoaming kit on my '06 SR5. It was not hard. Results are great! Search youtube for video to remove door panel. And another to do refoaming. You cant tell the speakers are bad until you pull the gasket off. The foam was cracked all the way around on mine.
    Quote Originally Posted by Milk_Badger View Post
  16. #15
    Join Date
    Aug 2009
    Location
    Earth
    Posts
    4,602
    Liked
    2168 times
    Images
    26
    Rep Power
    67158
    I did the Simply Speakers re-foam on my Tundra w/jbl (same fronts as the Sequoia) about a month ago. When I discovered the foam looked as if it should be glued to the back of the cone, I called them. Learned it was intended to be glued to the back, but could be glued to the front and their techs actually glue them to the fronts with no problems. They also told me that these re-foam kits come from jbl and are the same exact foams used on the oem speakers. I didn't buy the truck new, but I'd imagine they sound just as they did when they were new.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Tags for this Thread
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
