Good shock choices for the rear - 2005 Sequoia
+ Reply to Thread
Results 1 to 11 of 11
Thread: Good shock choices for the rear - 2005 Sequoia
  1. #1
    Junior Member ShrimpBurrito is a splendid one to behold. ShrimpBurrito is a splendid one to behold. ShrimpBurrito is a splendid one to behold. ShrimpBurrito is a splendid one to behold. ShrimpBurrito is a splendid one to behold. ShrimpBurrito is a splendid one to behold. ShrimpBurrito is a splendid one to behold. ShrimpBurrito is a splendid one to behold. ShrimpBurrito is a splendid one to behold. ShrimpBurrito is a splendid one to behold.
    Join Date
    May 2007
    Location
    Los Angeles, CA
    Posts
    56
    Liked
    0 times
    Rep Power
    13
    Default What do you recommend for rear shocks - 2005 Sequoia?
    I have an 05 Sequoia with ~63,000 miles. We tow a ~4,000 lb trailer a fair amount, and the vehicle is starting to hit the stops more now than it used to. We've got some unpleasant road "features" on I-405 here in SoCal, and when towing or with 4+ adults, I usually hit the stops when running through a dip or even a big bump going into a gas station or something. Parked and unloaded, the vehicle appears to be at normal height, and the springs are not visually defective, so I don't think they are to blame. I sense the shocks are simply allowing the rear end to compress too rapidly. Also, when looking at the shock, the space in between the shock cylinders is not uniform -- so they at least while the vehicle is at rest, the cynlinders are fitting together crooked. Maybe that's no big deal. There are no visual signs of leakage.
    I don't want to lift the vehicle at all -- I want especially stock height and ride (although a little stiffer, i.e. more dampening) wouldn't be bad. I also want something that is going to last longer, as this has probably been going on for 10k miles. I searched the forums quite a bit, and have come up with these options as replacements:
    OME 600002 - not officially supported for the Sequoia, but several folks have used them. It's not clear to me whether I would get any lift vs. OEM though. Is the ride comparable?
    Bilstein 4600 or 5100 or HD - Is HD and one of these others the same thing?
    Monroe SensaTrac - I've had these in the front of my Jeep Cherokee and have been pleased, but they don't do nearly the duty the ones on the Sequoia will be under. Certainly seems like the cheapest, although cost isn't a huge factor if the premium is worth it.
    KYB K344406 - an OEM supplier, probably the closest thing to OEM, including build quality.
    Any suggestions?
    Many thanks.
    Dave
    Attached Thumbnails Attached Thumbnails Good shock choices for the rear - 2005 Sequoia-left-1stview.jpg   Good shock choices for the rear - 2005 Sequoia-right-1stview.jpg   Good shock choices for the rear - 2005 Sequoia-right-2ndview.jpg
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Lurking Member chippewa is on a distinguished road.
    Join Date
    Jun 2012
    Location
    Little Elm, TX
    Posts
    33
    Liked
    0 times
    Rep Power
    1
    Default Re: Good shock choices for the rear - 2005 Sequoia
    Bilstein 4600's are an HD shock and will definitely improve the ride over an OEM shock. I don't believe they make a 5100 for the rear. If I am wrong, someone speak up because I would like to get 5100's all the way around and not just on the front. I have 4600's on my Ford diesel truck and could probably only be happier if I had 5100's on it. Bilstein is very hard to beat. IMO.
    Dustin. 2001 Sequoia SR5 4WD 70,000 MILES
  4. #3
    Lurking Member cruss77 is on a distinguished road. cruss77's Avatar
    Join Date
    Feb 2009
    Location
    Nashville, TN
    Posts
    31
    Liked
    1 times
    Rep Power
    5
    Toytec offers a set Bilstein 5100s for the rear from the FJ/4Runner but they are for a 2" rear lift and I dont know how that translates to an truck that isnt lifted.
    You may want to look at adding air bags to the rear coils. I've read where a few members who haul travel trailers add this for load leveling and all around ride comfort.
  5. #4
    Join Date
    Jun 2012
    Location
    Little Elm, TX
    Posts
    33
    Liked
    0 times
    Rep Power
    1
    Thanks for the info Cruss. We'll make 'em fit.
  6. #5
    Join Date
    May 2007
    Location
    Los Angeles, CA
    Posts
    56
    Liked
    0 times
    Rep Power
    13
    Thread Starter
    Thanks to you both for the replies. I'll definitely take a closer look at the 4600s. Does anyone have experience with the OME's on the Sequoia?
    Dave
  7. #6
    Join Date
    May 2007
    Location
    Los Angeles, CA
    Posts
    56
    Liked
    0 times
    Rep Power
    13
    Thread Starter
    I bought the Bilstein 4600s. Will report back after they are installed.
    Dave
  8. #7
    Veteran Member czechm8 is a glorious beacon of light. czechm8 is a glorious beacon of light. czechm8 is a glorious beacon of light. czechm8 is a glorious beacon of light. czechm8 is a glorious beacon of light. czechm8 is a glorious beacon of light. czechm8 is a glorious beacon of light. czechm8 is a glorious beacon of light. czechm8 is a glorious beacon of light. czechm8 is a glorious beacon of light. czechm8 is a glorious beacon of light. czechm8's Avatar
    Join Date
    Sep 2004
    Location
    Clive, IA
    Age
    48
    Posts
    1,697
    Liked
    14 times
    Images
    25
    Rep Power
    152
    I had the 5100's and 4600's put on my '05 a couple weeks ago. Good setup! I leveled the front with the 5100's.
    I don't think you'll be disappointed.
    05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Toyo tires, MagnaFlow cat-back, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner, HD Radio tuner. HAT tweeters, Scanspeak mids and DLS coaxials, TRU B-2110 and H-1 amps, 13" eD sub, iPod hookup. SilverStar Ultra lamps, Bilsteins all around.
  9. #8
    Join Date
    May 2007
    Location
    Los Angeles, CA
    Posts
    56
    Liked
    0 times
    Rep Power
    13
    Thread Starter
    Got my 4600's installed on the rear (Bilstein part #24-185813), and handling is much improved. Pretty close to the OEM ride if I recall. Once I got the old ones out, it was easy to see where they had leaked, as I had expected.
    Dave
  10. #9
    Supporting Vendor AJUSA.com comes in many shapes and sizes. AJUSA.com comes in many shapes and sizes. AJUSA.com comes in many shapes and sizes. AJUSA.com comes in many shapes and sizes. AJUSA.com comes in many shapes and sizes. AJUSA.com comes in many shapes and sizes. AJUSA.com comes in many shapes and sizes. AJUSA.com comes in many shapes and sizes. AJUSA.com comes in many shapes and sizes. AJUSA.com comes in many shapes and sizes. AJUSA.com comes in many shapes and sizes. AJUSA.com's Avatar
    Join Date
    Jul 2011
    Location
    San Diego, CA
    Posts
    717
    Liked
    56 times
    Rep Power
    3933
    The 4600 is a great stock replacement and will provide that extra support you are looking for without being uncomfortable. They are much better riding and handling shocks than stock. No 5100 for the stock height rear, the FJ shocks are to long for a stock application.
    Bilstein 24-185813 Monotube Shock Absorber | AJUSA.com
  11. #10
    Lurking Member Justinpm1994 is on a distinguished road.
    Join Date
    Jan 2012
    Location
    Lafayette
    Posts
    25
    Liked
    0 times
    Rep Power
    2
    What price can i expect to pay to get both rear shocks changed? I want the ride to be as close as possible to stock, and im not lifted or anything. Its a 2002. Thanks
  12. #11
    Junior Member Padron is a name known to all. Padron is a name known to all. Padron is a name known to all. Padron is a name known to all. Padron is a name known to all. Padron is a name known to all. Padron is a name known to all. Padron is a name known to all. Padron is a name known to all. Padron is a name known to all. Padron is a name known to all.
    Join Date
    Aug 2009
    Location
    Over there
    Posts
    177
    Liked
    1 times
    Rep Power
    294
    I need rear shocks too.....Anybody running Icon rear shocks on their Sequoia?
    2006 Sequoia Limited 4wd.....Black
    AFE Dry Drop in Air Filter, NGK Iridium plugs, ASP Underdrive Crank Pulley, Mobil1 Oils, PureOne PL20195 Oil Filter, Stebel 300hz Horn, Total Chaos UCA's, Total Chaos Diff Drop, ICON 5-8625 Coilovers, Energy Suspension Steering Rack & Sway bar bushing kits, 285/70/17's TreadWright MT's, EBC Slotted and Dimpled Rotors, EBC YellowStuff Pads, Motul 5.1 DOT Brake Fluid, Goodridge 6 Piece Stainess Steel Braided Brakeline Kit
    more to come....
Posting Permissions
  • You may not post replies
  • You may not edit your posts
