Locks Only Work When Car Is On
+ Reply to Thread
Results 1 to 2 of 2
Thread: Locks Only Work When Car Is On
  1. #1
    Rookie peteranthony11 is on a distinguished road.
    Join Date
    Mar 2012
    Location
    United States
    Posts
    7
    Liked
    0 times
    Rep Power
    0
    Default Locks Only Work When Car Is On
    Ive looked around and couldn't seem to find anything about this
    Recently I have been unable to lock/unlock my doors when the ignition is off, when i turn the ignition on however, it works perfectly. I checked all the fuses and none seem to be blown.
    It seems to me that this I tripped some sort of security thing because the indicator light doesnt light up when the car is off and also the dome lights do not turn on and the indicator light on the db doesnt light up also when the ignition is off.
    I hope someone could figure this out before i take it in to the dealer
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Lurking Member chippewa is on a distinguished road.
    Join Date
    Jun 2012
    Location
    Little Elm, TX
    Posts
    33
    Liked
    0 times
    Rep Power
    1
    Default Re: Locks Only Work When Car Is On
    sounds like a defective door jamb switch. It's conical shaped rubber plunger switch that is pushed in when the door is closed. Unplug each switch one at a time and try to lock the doors. This might help you isolate the defective switch. Report back with what you find.
    Dustin. 2001 Sequoia SR5 4WD 70,000 MILES
Posting Permissions
  • You may not post replies
  • You may not edit your posts
