Old 01-16-2004, 01:50 PM
Eric4wd's Avatar
Last Online: 12-06-2004 02:30 PM
Eric4wd is on a distinguished road.
Eric4wd's Photo Albums
Default Very strange noise
I take it this is due to the fact that it's been butt cold lately (-22F without wind chill factor) here in eastern Canada. Nonetheless I'm still trying to figure out what the heel is this noise. It happens unexpectedly while cruising (not speed dependant). It is a loud HUM coming from the middle of the dashboard and I would say near the firewall. When I shut off the ventilation, it goes away. Conversely, If I leave the ventilation on and come to a complete stop, the noise goes away too. When I accelerate and hit around 30mph, the noise reappears. Anyone had this happened before? It's a 2002 Seq limited with 22K miles.
Old 01-16-2004, 02:08 PM
peid's Avatar
Dealer : Billion Motors
1996 Toyota T100
Last Online: 01-05-2009 08:49 AM
Images: 31
peid is on a distinguished road.
peid's Photo Albums
Don't have it but sounds like your condenser.
I believe Toyota's condensers turn off during hard acceleration to prevent loss of power when needed.
This would sound likely as you indicate it also goes away when you turn off your system.
It can vary depending on your speed at do it throughout the entire speedometer. Depending if your truck shifts out of the gear to a different gear to gain more power.
That is my guess.
1996 T100, 180,000 and counting
Old 01-16-2004, 02:26 PM
Eric4wd's Avatar
Isn't the condensor only working with A/C? Mine was switched off when all this happened and I wasn't accelerating hard either. Sounds like there's a motor somewhere feeding the heated air into the cabin that is about to give. It only happened twice this month so it'll be hard showing this to a service rep.
Old 01-16-2004, 02:34 PM
peid's Avatar
1996 Toyota T100
Images: 31
peid's Photo Albums
The condenser is also working with either Defrost modes.
It doesn't require pedal to the metal acceleration, just enough to maybe kick it out of over drive.
Like I said, I don't know for sure, but that is what it sounds like to me.
Old 01-16-2004, 09:42 PM
Bbbutch's Avatar
2002 Toyota Tundra,
2005 Toyota Highlander Wife's Highlander
Last Online: 10-21-2009 12:12 AM
Bbbutch is on a distinguished road.
Bbbutch's Photo Albums
Probably not the problem but you should still check to see if the weather strip that goes accross the top of the fire wall and makes contact with the back of the hood is still in place.
Old 01-17-2004, 11:35 AM
Brian M's Avatar
Dealer : Sand Dollar Toyota Scion
2003 Toyota Sequoia
Last Online: 06-09-2009 11:24 PM
Brian M is on a distinguished road.
Send a message via AIM to Brian M Send a message via Yahoo to Brian M Brian M's Photo Albums
Are you 4wd? Some have had a noise emitting from the front dif.
2003 Sequoia SR5 - Phantom Gray
2006 F150 SuperCrew Lariat - Black/Gold
Old 01-19-2004, 08:32 AM
Dealer : Russel Toyota
Last Online: 03-12-2006 06:51 PM
Stooge is on a distinguished road.
Stooge's Photo Albums
The Tundra sometimes makes this noise as the AC compressor cycles (AC or defrost mode). Sounds almost like a circular saw. It's actually the refrigerant throttling through the orifice in the condenser. My charge was OK and everything works fine, so I have learned to ignore it.
