pinion gear diy, upgrades while I'm at it??
+ Reply to Thread
Results 1 to 4 of 4
Thread: pinion gear diy, upgrades while I'm at it??
  1. #1
    Join Date
    Nov 2011
    Location
    Pinetop, AZ
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Default pinion gear diy, upgrades while I'm at it??
    hello, I have a 2004 Sequoia SR5 4x4 w/ about 160k miles on it. I just found out that the pinion bearing needs replaced, and it was recommended that I do the carrier bearings and possibly axle bearings while I'm at it. I trust the shop and he was willing to give me some help if I do it myself, or he said it would be $700-800 for them to do it. I am more than willing to try it myself, but things like crush sleeves (?) and back lash make me a little nervous. I did the timing belt myself with the help of alldatadiy, but they don't have any repair instructions on doing anything with the diff, other than prices. Can anyone recommend a site that would have detailed instructions on how to do this, or should I just suck it up and pay the mechanic?
    Usually when I do a diy, it's my excuse to add some upgrades and fix other things with the money I am "saving." I abuse this thing as much as possible, and am always very impressed with some of the places it has taken me, and gotten me out of. I hunt with it frequently, and I pull a 16' double-axle trailer to either tow my 1972 Int'l Scout or load up with a cord or two of firewood. I'm thinking I need to upgrade my old suspension, possibly adding a small lift and trailer brake connection, and maybe even air bags. At the same time, it's my wife's family car when I'm not out beating on it, so I need to keep it wife-friendly (not too high, not extremely rough riding). Any suggestions? The airbags probably wouldn't be necessary, but I would like to get some feedback from others that have done similar things. Since I might have it taken apart in the garage for a while, this is probably the time to do some of this. Thanks for your help,
    Rob
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Nov 2008
    Location
    Hermitage
    Posts
    250
    Liked
    3 times
    Rep Power
    7
    Default Re: pinion gear diy, upgrades while I'm at it??
    I think the stock replacement should be fine on this, the air bags will help if you have sag when towing and not affect the ride the rest of the time. I put on 100series Land Cruiser rear springs and like them when it is loaded down, but it is stiffer when unloaded.
  4. #3
    SAS'ed #5 dyogim's Avatar
    Join Date
    Sep 2000
    Location
    Co.Co. County, CA.
    Age
    37
    Posts
    6,601
    Liked
    411 times
    Images
    119
    Rep Power
    27120
    Ditch the crush sleeve and get yourself a solid spacer to replace the crush sleeve. You can purchase it from one of the authorized dealers on this site. I believe it's East Coast Gear Supply.
    You'll need purchase a master install kit. This will have the shims, bearings and races to get the pinion and carrier bearings done. For the rest of the axle, get them from the auto parts store. The box brand may be different but a lot of the times, they are just using another brand for the actual bearing. Such as Koyo bearings. Replace the inner and outer wheel seals. Other than that, you should be good. Unless, you want to regear...
    There's a lot of info provided here: Toyota Gear Installs
  5. #4
    Join Date
    Nov 2011
    Location
    Pinetop, AZ
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    thanks for the posts. I decided to just turn it over to the expert and deal with the suspension later
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
