Question What is leaking? Head gasket?
+ Reply to Thread
Results 1 to 6 of 6
Thread: What is leaking? Head gasket?
  1. #1
    Rookie Lars_SC is on a distinguished road.
    Join Date
    Dec 2012
    Location
    Vereinigte Staaten
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Default What is leaking? Head gasket?
    Hello,
    since some weeks I noticed a minor loss of coolant fluid but couldn't discover why. Today I parked the car (engine cold) slighlty uphill/front higher than rear and after a few minutes it started dripping under the car... The dripping stopped when the car was parked on leveled surface again.
    The leakage is on the front right side of the engine. It looks as if the fluid comes out between cylinder head and the crank case - see attached picture. It is taken front under the car looking up from the rear to the front on the right side of the engine.
    Do you know what is leaking? Is it really the cylinder head gasket or is it something else.
    Thanks!!
  2. #2
    Junior Member sseaman is on the right track. sseaman is on the right track.
    Join Date
    Nov 2008
    Location
    Hermitage
    Posts
    250
    Liked
    3 times
    Rep Power
    5
    Default Re: What is leaking? Head gasket?
    If there aren't any traces of coolant above it looks like it could be the gasket, unless it is further up and running back when you had it parked uphill.
  3. #3
    Junior Member pewter05 is a glorious beacon of light. pewter05 is a glorious beacon of light. pewter05 is a glorious beacon of light. pewter05 is a glorious beacon of light. pewter05 is a glorious beacon of light. pewter05 is a glorious beacon of light. pewter05 is a glorious beacon of light. pewter05 is a glorious beacon of light. pewter05 is a glorious beacon of light. pewter05 is a glorious beacon of light. pewter05 is a glorious beacon of light.
    Join Date
    Nov 2008
    Location
    Harrisburg, PA
    Posts
    77
    Liked
    1 times
    Rep Power
    169
    Water pump.
  4. #4
    SAS'ed #5 dyogim has mentally logged off-topic. dyogim has mentally logged off-topic. dyogim has mentally logged off-topic. dyogim has mentally logged off-topic. dyogim has mentally logged off-topic. dyogim has mentally logged off-topic. dyogim has mentally logged off-topic. dyogim has mentally logged off-topic. dyogim has mentally logged off-topic. dyogim has mentally logged off-topic. dyogim has mentally logged off-topic. dyogim's Avatar
    Join Date
    Sep 2000
    Location
    Co.Co. County, CA.
    Age
    34
    Posts
    6,297
    Liked
    170 times
    Images
    119
    Rep Power
    14543
    You may want to do a compression check for each of the pass. cylinders to be sure it's not a head gasket. This will at least give you some knowledge and you can start ruling things out. You should do this ASAP.
  5. #5
    dx3
    dx3 is offline
    Junior Member dx3 is on the right track. dx3 is on the right track.
    Join Date
    Nov 2009
    Location
    Tulsa, OK
    Posts
    100
    Liked
    0 times
    Rep Power
    4
    If it was that bad of a HG leak you would have overheated many times by now...
    Jonny
    02 Toyota Sequoia
    06 VW Jetta TDI
    97 Lexus SC300
  6. #6
    Lurking Member Zackaroo is on a distinguished road.
    Join Date
    Jan 2005
    Location
    Melbourne
    Posts
    31
    Liked
    0 times
    Rep Power
    9
    I had a hairline crack in my top radiator tank on the engine side. Stick your head over the radiator and look back at it to check there.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
