Slight Hesitation during Accleration... no Codes... Help please
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Like Tree1Likes
Thread: Slight Hesitation during Accleration... no Codes... Help please
  1. #1
    Junior Member Chinee has done just about everything...and then some. Chinee has done just about everything...and then some. Chinee has done just about everything...and then some. Chinee has done just about everything...and then some. Chinee has done just about everything...and then some. Chinee has done just about everything...and then some. Chinee has done just about everything...and then some. Chinee has done just about everything...and then some. Chinee has done just about everything...and then some. Chinee has done just about everything...and then some. Chinee has done just about everything...and then some. Chinee's Avatar
    Join Date
    Nov 2002
    Location
    Wellington, FL
    Posts
    219
    Liked
    3 times
    Rep Power
    956
    Default Slight Hesitation during Accleration... no Codes... Help please
    Posted this in the Technical Forum as well.
    2002 Sequoia, 250K miles
    Been having rough acceleration for the last month or so, and I cannot find the problem. No codes, so that makes it harder. It happens intermittently and mostly when:
    - Using Cruise Control, you can feel the slight misses (light sputtering), not enough to create a jerky action, but it is there every 5-10 seconds
    - Accelerating from a slow down while turning, e.g. turning right through a Yield sign, sometimes there's enough hesitation for there to be a jerk
    - Accelerating very slowly from 20 to 50 mph, you can feel the light sputtering and occasionally there'll be a small jerk
    What I've done:
    - Changed plugs in Feb 2012, just 17K miles ago, NGK Iridiums, pulled plugs last night and inspected, gaps were at .031, no carbon buildup or otherwise
    - Cleaned intake with carb cleaner
    - Changed fuel filter
    - Ran a tank with Seafoam
    - Changed air filter
    - I also changed the TPS a few months ago after getting the appropriate code, maybe I messed up on the install?
    Thinking:
    - ignition coils
    - TPS
    - the other TPS (forgot the name, APPS?, on the other side of the intake)
    - changing the plugs
    - adding a water remover to gas tank
    But remember no codes, which would indicate problems with the TPS and ignition coils.
    Any ideas anyone?
  2. #2
    Lurking Member henway2 is on a distinguished road.
    Join Date
    Mar 2010
    Location
    Dallas
    Posts
    30
    Liked
    4 times
    Rep Power
    4
    Default Re: Slight Hesitation during Accleration... no Codes... Help please
    When you say "no codes", what does that mean?
  3. #3
    Join Date
    Nov 2002
    Location
    Wellington, FL
    Posts
    219
    Liked
    3 times
    Rep Power
    956
    Thread Starter
    ... from the OBD Scan Tool, no Check Engine Light.
  4. #4
    Veteran Member tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,162
    Liked
    194 times
    Images
    27
    Rep Power
    8732
    did you clean the MAF? and if so did you use MAF cleaner?
    2000 Tundra Platinum Metallic 3.4L V6 SR5 AC 4WD, 198,000 miles and counting, Husky Liners, 5000K 35 Watt HI/LO HIDs, LED OEM Fog Lights w/ Fog Modification from IZL, LED Cargo Light, Pioneer DEH 3300UB CD RDS, redruM69's Aluminum Billet Access Cab Window Arm Mod, Kicker 8" Sub with Custom Box, New Frame via The Rust Recall, Bilstein 5100s on 3rd Notch, CV Boot Clamp Mod, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & Interior LEDs, 285/75r16 Terra Grapplers, 5000K 35 Watt HID Fogs
    CBTMA Member
    Sometime in the Future:
    Offroad LEDs, Keyless Entry, Tow Hitch
  5. #5
    Join Date
    Mar 2010
    Location
    Dallas
    Posts
    30
    Liked
    4 times
    Rep Power
    4
    This has been described by many Sequoia owners, including myself. So far, no one has found the cause. The cause of this hesitation is very difficult to track down, because so many factors are involved, like you mention.
    Sequoia Bogging Down
    I wish you luck in finding the cause of this problem, it has been bothering me for 4 years now.
    2002 Toyota Sequoia SR5 4WD 108,000 mi.
  6. #6
    Join Date
    Nov 2002
    Location
    Wellington, FL
    Posts
    219
    Liked
    3 times
    Rep Power
    956
    Thread Starter
    Quote Originally Posted by tundra3400 View Post
    Can you suggest a cleaner before I go out there trolling the auto parts store?
  7. #7
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,162
    Liked
    194 times
    Images
    27
    Rep Power
    8732
    any MAF cleaner they have works as long as it says safe to use on MAF sensors. just take out the sensor( 2 small screws) and unplug it. let it try completely for a few mins and reinstall it.
    CBTMA Member
  8. #8
    Join Date
    Nov 2002
    Location
    Wellington, FL
    Posts
    219
    Liked
    3 times
    Rep Power
    956
    Thread Starter
    Cleaned the MAF, first time in 250K miles... no change. Will probably head to the dealer next week, but thinking about changing plugs today to so if it might me a bad plug that's firing intermittently.
    Has anyone gone to the dealer to investigate this issue?
  9. #9
    Junior Member spinn is on the right track. spinn is on the right track. spinn is on the right track. spinn is on the right track. spinn's Avatar
    Join Date
    Oct 2006
    Location
    SF Bay Area
    Posts
    191
    Liked
    2 times
    Images
    4
    Rep Power
    8
    I don't have the same problem, as my decrease in acceleration only seems to occur at around 70-75mph, whether out/in cruise-control mode, and it's intermittent. I've only seen it once mentioned that it could be the catalytic converters getting clogged up at full throttle. Not saying that's your problem, but with that many miles (I have +200K), maybe your cats could be getting bad.
  10. #10
    Join Date
    Nov 2002
    Location
    Wellington, FL
    Posts
    219
    Liked
    3 times
    Rep Power
    956
    Thread Starter
    Update... After 1,400 miles and 32 days, I am cautiously optmistic that it's fixed. I was researching cat converters to see what the specific symptoms of failing cats would be... didn't match up to my problems. Saw a FB post about a GS400 having hesitation and stuttering between 1100 and 2200 rpm... very much like my Seq, but the specific problem and solution were not listed. It mentioned the GS having a 1UZFE engine, which has a similar lettering code to our 2UZFE engine (still have no idea if the engines are similar), and that caused me to go cruising the Lexus forums. Found someone with an ES with similar problems, (but it has a V6, not a V8 like the Seq's) and it turned out to be EGR and idle control issues; decided to check my PCV. I pulled it and it rattled, so it should be good, decided to blast some Carb Cleaner through both ends and shake it up some. Re-installed and after a 9 mile test drive the hesitation and stuttering seem to be gone.
    I am still not 100% sure it's fixed, since it's nighttime and the temps are lower, 60's, so it performs differently from during the daytime, but I will be checking it out during my errand runs tomorrow. I will be back with another post tomorrow.
  11. #11
    Join Date
    Nov 2002
    Location
    Wellington, FL
    Posts
    219
    Liked
    3 times
    Rep Power
    956
    Thread Starter
    My optimism just went out the window... Damn!
  12. #12
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,162
    Liked
    194 times
    Images
    27
    Rep Power
    8732
    you might want to have the idle speed control motor cleaned. my v6 tundra has one and it would do the same things you are describing. in not exactly sure where it is but its on the intake/TB somewhere.
    CBTMA Member
  13. #13
    Join Date
    Nov 2002
    Location
    Wellington, FL
    Posts
    219
    Liked
    3 times
    Rep Power
    956
    Thread Starter
    The V6 Tundras have an Idle Air Control Valve, the V8s have a Throttle Control Motor, attached to theTPS, Throttle Position Sensor. Researching these now.
  14. #14
    Join Date
    Nov 2002
    Location
    Wellington, FL
    Posts
    219
    Liked
    3 times
    Rep Power
    956
    Thread Starter
    Update... cleaning the PCV valve did result in an improvement; the hesitation was less often and softer, so I replaced the PCV on Friday. Also changed the plugs, took out the 10-month old NGK Iridiums with ~18K miles and replaced them with the common NGK plugs, about $2.30 each. I was almost ready to say the symptoms were gone. But today I was going at a steady cruise, just under 50mph, rpms in between 1500 and 2K, accelerated slightly, and I felt hesitation. Very soft and almost imperceptible, but it was there, about 3 stutters. Tried to reproduce it for the next 3-4 miles but could not.
    At this point, I am returning the Seq to the wife and let her tool around in it for a spell to see if the hesitation returns with her; I suspect it will. Getting a little frustrated, even looked up the kbb price, about $4,000. I will likely monitor the performance over the next few weeks and see what happens... fingers are crossed.
  15. #15
    Junior Member turboDan is on a distinguished road.
    Join Date
    May 2011
    Location
    Connecticut
    Posts
    65
    Liked
    1 times
    Rep Power
    3
    I am almost willing to bet that one of your ign coils is on the way out.The problem is as you well know that you have 8 of them and without having a code to point you in the right direction you may have to wait til it fails completely I have seen them begin to fail on secondary side of coil and the computer never picks it up and sets a code.That is why i say you may have to wait til it dies out completely.It is hard to diagnose an intermittent problem such as the one you are experiencing while doing so over the internet and without the correct monitoring tools.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
