2006 Sequoia RSE ECU Access for BT35-TOY Module??
+ Reply to Thread
Results 1 to 2 of 2
Thread: 2006 Sequoia RSE ECU Access for BT35-TOY Module??
  1. #1
    Rookie Spacejam is on a distinguished road.
    Join Date
    Dec 2012
    Location
    SO CAL - Orange County
    Posts
    9
    Liked
    0 times
    Rep Power
    0
    Default 2006 Sequoia RSE ECU Access for BT35-TOY Module??
    Can someone provide a step by step in accessing the RSE ECU? I am going to be mounting the BT35-TOY in there and when you have RSE it goes in RSE ECU. Searched and found no step by step on what to unscrew and take out to access this in the center cupholder area where the storage bin is. Any info is appreciated!!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Lurking Member NotSoSimple is on a distinguished road.
    Join Date
    Jan 2013
    Location
    Hillsboro, OR
    Posts
    49
    Liked
    1 times
    Rep Power
    1
    Default Re: 2006 Sequoia RSE ECU Access for BT35-TOY Module??
    This is for a 2003 but it should be close: http://www.tundrasolutions.com/forum...s_location.pdf
    Notice It is under the console. So take a look at this: 2003 Yaw rate / decelerator sensor diy That should walk you through removing the console.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
