Brake Booster hissing
+ Reply to Thread
Results 1 to 4 of 4
Thread: Brake Booster hissing
  1. #1
    Join Date
    May 2010
    Location
    California
    Posts
    88
    Liked
    0 times
    Rep Power
    6
    Default Brake Booster hissing
    2001 Sequoia Limited 4X4 - the brake booster is hissing loudly and diminishes when the brake pedal is pushed or engine speed increases. Does anyone know just what is defective and what part is required to correct it? Is it a simple seal or the complete booster? I cannot find breakdown diagrams of the booster components, so it remains a "mystery". The braking performance appears normal, so I wonder just how serious this leaking is to overall function. The vehicle has skid control, which is important when considering the booster replacement.
    Any thoughts would be appreciated.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member TuRDs/c's Avatar
    Join Date
    Mar 2012
    Location
    wa
    Posts
    111
    Liked
    24 times
    Rep Power
    4
    Default Re: Brake Booster hissing
    Sounds Like A Vacuum Leak. Check The Hoses If They Are Tight And Not Cracked Then Its In The Booster. I Don'tKnow Enough To Tell You If You Can Fix It Or Have To Replace It Though. Good Luck.
  4. #3
    Join Date
    Mar 2012
    Location
    None
    Posts
    20
    Liked
    0 times
    Rep Power
    4
    Had the same problem on my 2003 sequoia, dealer replaced brake booster under warranty.
    Sent from AutoGuide.com Free App
  5. #4
    Join Date
    Jul 2005
    Location
    New England
    Posts
    1,225
    Liked
    420 times
    Images
    25
    Rep Power
    24550
    Air leak around the pushrod seal. Booster is non-serviceable unfortunately. Must be replaced. $$$$.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
