Transmission Temperatures using Torque App and OBDII Bluetooth Adapter
+ Reply to Thread
Results 1 to 10 of 10
Thread: Transmission Temperatures using Torque App and OBDII Bluetooth Adapter
  1. #1
    Junior Member Soder99's Avatar
    Join Date
    Jan 2010
    Location
    Lehi, Utah
    Posts
    59
    Liked
    0 times
    Images
    3
    Rep Power
    6
    Default Transmission Temperatures using Torque App and OBDII Bluetooth Adapter
    I ordered an inexpensive OBDII Bluetooth OBDII adapter off Amazon and the $5 Torque Android App and was excited to observe transmission temps while towing my 4,000 lb. boat. Unfortunately Torque wouldn't display the transmission temp.
    I used some PID's posted on TacomaWorld.com and both of these produced an output of about 125F as I drove around my neighborhood. I didn't see different readings for them as I drove, but it was a 3 minute trip.
    Write-Up: Torque APP OBD2 Reader - Page 10 - Tacoma World Forums
    We drove down to the lake in 100F weather last week. It was about 300 miles down and 300 miles home.
    The converter outlet temp consistently ran higher than the pan temp by about 5-10F. At it's hottest, the converter temp got up to 212F accelerating up a hill after a stoplight. Once we got on I-15 the converter temp ran about 198F.
    Everything ran as appropriate except that we got about 7.5 mpg (we dropped about 2,500 ft. in elevation on the way down). On previous trips we got about 9 mpg. So I looked at the air filter and it was ugly. I banged it out and we got about 8.5 mpg on the way home (uphill). A new one is going in tomorrow.
    We came home late at night. The ambient temperature was about 72F (average) and the converter outlet temp ran closer to 165F.
    I'm very pleased that these Torque PID's worked to show me the Sequoia transmission temperatures in real time. I never had a problem with the app nor my OBDII bluetooth adapter.
    I know some of these inexpensive OBDII's are flaky or don't work. If anyone is interested, I bought mine on Amazon under this title for $15:
    Newest Elm327 Bluetooth V1.5 OBD2 OBD II Auto Diagnostic Scanner Mini Adapter
    by ELM 327
    Hopefully this information will be useful if others are trying to use the Torque app to monitor transmission temps in their Sequoia.
    Here's the PID's:
    For sensor 1 (Pan Temp):
    OBD2 Mode and PID:
    21D9
    Long Name:
    Transmission Fluid Temperature 1
    Short Name:
    TFT 1
    Minimum Value:
    0.0
    Maximum value:
    220.0
    Scale factor:
    x1
    Unit Type:
    F (there is a degree symbol in Torque)
    Equation:
    ((((E*256)+F) * (7/100) 400)/10)
    OBD Header to use:
    left blank
    For sensor 2 (Converter outlet temp):
    OBD2 Mode and PID:
    21D9
    Long Name:
    Transmission Fluid Temperature 2
    Short Name:
    TFT 2
    Minimum Value:
    0.0
    Maximum value:
    220.0
    Scale factor:
    x1
    Unit Type:
    Equation:
    ((((G*256)+H) * (7/100) 400)/10)
    OBD Header to use:
    left blank
    2005 Sequoia SR5 4x4 - Intended for use in the mountains and towing the boat to lakes...actually used to be a "responsible" parent and take the kids from place to place?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Feb 2014
    Location
    Little Rock
    Posts
    14
    Liked
    1 times
    Rep Power
    0
    Default Re: Transmission Temperatures using Torque App and OBDII Bluetooth Adapter
    This seems to works great on my 2007 Sequoia ! Thanks ! What temps do you see just idling?
  4. #3
    Junior Member SteveInCal's Avatar
    Join Date
    Dec 2008
    Location
    San Rafael, CA
    Posts
    140
    Liked
    8 times
    Rep Power
    7
    Thanks for resurrecting this thread! I also want to determine trans temps on my 2005. It has close to 170,000 miles, and I'd like to see the temps while towing my boat.
    Back in early January, I bought the BAFX Bluetooth OBD2 Scan Tool off Amazon, and downloaded the Torque App. However, I couldn't get the trans temps to work, and never made time to figure out the process.
    Using this information from Soder99, I was able to program the temps into Torque, and they worked perfect on the way to work this morning - woo hoo!
    Here is a Torque screenshot from this morning. The temps are after I drove ~10 miles to work. Looking good so far...
    Click image for larger version.
  5. #4
    Join Date
    Feb 2014
    Location
    Little Rock
    Posts
    14
    Liked
    1 times
    Rep Power
    0
    Yea, This was awesome doing my transmission fluid flush. Mine was running about 110 at the pan idling, but it around 30 degrees outside. Thanks Soder99
  6. #5
    Join Date
    Dec 2008
    Location
    San Rafael, CA
    Posts
    140
    Liked
    8 times
    Rep Power
    7
    Quote Originally Posted by vman858 View Post
    According the manual, you're supposed to have your trans fluid temp between 115˚F and 130˚F when you set the final level using the overflow plug. If you were at 110˚F your level might be a little off, probably a hair too high...
  7. #6
    Join Date
    Jul 2005
    Location
    New England
    Posts
    1,292
    Liked
    452 times
    Images
    25
    Rep Power
    27579
    Quote Originally Posted by SteveInCal View Post
    Coefficient of thermal expansion of ATF is about 0.0004/degree F
    So, 13 quarts x .0004 x 12.5 = 2.1 fluid ounces overfill.
    So, one hair equals about two fluid ounces.
  8. #7
    Join Date
    Dec 2008
    Location
    San Rafael, CA
    Posts
    140
    Liked
    8 times
    Rep Power
    7
    Quote Originally Posted by mibro View Post
    That's good knowledge
  9. #8
    Join Date
    Feb 2014
    Location
    Little Rock
    Posts
    14
    Liked
    1 times
    Rep Power
    0
    I put it in drive with the ebrake on and foot on the brake. Gave it a little gas and got pan temp up to 130. Let it go down to about 122 and did the check. I think I'm good. Thanks!
  10. #9
    Supporter corc305's Avatar
    Join Date
    Oct 2010
    Location
    Henderson, NV
    Posts
    154
    Liked
    63 times
    Rep Power
    2813
    I setup my Torque app on android with the PIDs above and it doesn't register. I have an 03 with a manufacture date of Aug 02. I thought the scanguage could read our trans temps so I'm hoping someone can offer an assist here...
    I'm getting ready to install the flex-a-lite fan and want a baseline for my trans temp.
    2015 Tundra Limited Crewmax, 4x4, Black
    2003 Tundra V8, Black, Access Cab
    - 2002-2014 - Great truck!!
  11. #10
    Lurking Member toyzinthehood's Avatar
    Join Date
    Aug 2014
    Location
    NE Wyoming
    Posts
    21
    Liked
    9 times
    Images
    2
    Rep Power
    2
    Thanks for the info, just placed my order for this!
    2007 Sequoia SR5
    Hella 700 series driving lights
    Bilstein 5100 set at 2" front
    Bilstien 4600 in rear
    TRD air filter with charcoal filter delete
    Rage full length roof basket
    20% tint on front windows
    Total Chaos dif drop kit
    Amsoil
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
