DuckFan....the sound from the exhaust was extremely loud in the cabin when you were cruising at lower speeds (city driving) so they were to redo it to control the resonance.
tonyv....welcome to TS!! now get ready for a buttload of questions! so how is the S/C? any problems? was it worth the $$$? thanks in advance!
Chris
__________________ 2001 Sequoia 2WD SR5 Mods: Rollers - 18x9 JAOS Super Ziga wrapped w/ 285/65 BFG A/Ts, Suspension: SAW 2.0 Adj. Coilovers, UCAs, Rear Coilspacers I.C.E. - Clarion H/U w/ built in monitor, DVD Player, Drop Down, Headrest Monitors, Exterior: - Stock OEM Foglights, Wings West Spoiler, Engine:TRD Drop-In Filter
Originally posted by tonyv i have the exhaust and a supercharger on my 2002 sequoia. the exhaust has a deep tone from 700 to 2200 rpm .
tonyv - welcome! boy, the guys first post and he kicks our @$$ with the s/c and exhaust! j/k! how is the s/c? Are you having difficulties like the Tundra folks? Thanks and again, welcome to TS.
Please start a new thread for all of us to start asking questions. I'm curious what is your max PSI and what rpms are you notciing the SC. I also would like to know how your fuel efficiency is with a "Lead Foot" and a "Light Foot". Thanks
well trd said it is 7psi. i recived my boost gauge today from trd i will install it this weekend than i can get a good ideal of what it is . if you stay out of the supercharger my fuel performance stayed the same. running it i got 13 to 14 mpg. you feel the boost about 1500 to 2000 rpm if you unplug the bypass you feel it right away. if you do not press hard on the gas the bypass valve vents the boost so your fuel mileage should stay the same
Sounds like they pretty much repeated the same formula they had with the 4Runner SC. Thanks for the info! BTW - Do you have to use Premium Unleaded now versus regular?
i have had no problems with my supercharger. i have only used premium gas . in missouri it only $1.34 a gallon. the supercharger is the same for the tundras the drive belt and a fuse is the only thing diff
As I remember you have to use premium or else the car will sputter and knock really bad. But it is a joy to drive. When you hit that max PSI...Zoom...Zoom...Baby!!!
just finished installing my new trd cat-back system, it has a bigger ressonator after the muffler(ressonator seems to be made by magnaflow). the new set-up is a lot quieter, no more 2k res problem. it does have a louder rumbler b/w 700 rpm to about 2000 rpm, above this point it's alot quieter than the old system. the new set-up sounds more like a "european engine". overall i kinda like it better than the old one.
john
I drove off the lot with the EXH.........they took it out a week later. I just have to make an appointment to get down there and have Carson Toyota put the "NEW" Exhaust on.
