Try waiting a little longer for the lights to go off.
Say your driving along with the headlights on, you arrive at your destination,you shut off engine get out of vehicle and close the doors and lock them. The headlights should shut off with 15-60 seconds. This is programable at the dealer. The default mode is 30 seconds (I think).
There is no beeper due to the automatic feature.
DO NOT REACH IN AND TURN ON THE HEADLIGHTS. THE WILL NOT SHUT OFF AUTOMATICALLY THAT WAY.
The daytime running lights will automatically come on. The sensor is in the top of your dash, it tells the computer when to turn on the headlights. Dont cover this sensor or they will not function properly. The headlight switch does not have to be on, if it is the daytime running lights are overriden and the headlights will be on all the time.
Hope this helps
Victor
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
