Heated seats upgrade
+ Reply to Thread
Results 1 to 6 of 6
Thread: Heated seats upgrade
  1. #1
    Rookie dhclark's Avatar
    Join Date
    Apr 2002
    Location
    Bellingham, WA
    Posts
    9
    Liked
    0 times
    Rep Power
    0
    Default Heated seats upgrade
    We just picked up a 2002 desert sand Sequoia SR5. We got the SR5 rather than a limited b/c my wife wanted the desert sand color, which isn't available in the Limited version. We were able to get just about every option we wanted, except the heated seats. Our dealer has a company in Seattle that can retrofit heaters on our existing seats, but it won't be stock, and they don't use the system/buttons that are in the Limiteds.
    Do any of you know of a way to get stock heated seats in an SR5, or at least use the heating activation system in the Limiteds, to activate retrofitted seats?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member Simias's Avatar
    Join Date
    Dec 2000
    Location
    Orange County, CA
    Posts
    1,900
    Liked
    0 times
    Rep Power
    16
    dhclark,
    some time ago, if i remember correctly, a member got aftermarket seat heaters and used the LTD switches. you should ask the aftermarket company if they can use the stock swithes in place of their switches. i don't see why they couldn't because in most cases a switch is a switch.
    Chris
    2001 Sequoia 2WD SR5
    Mods:
    Rollers - 18x9 JAOS Super Ziga wrapped w/ 285/65 BFG A/Ts, Suspension: SAW 2.0 Adj. Coilovers, UCAs, Rear Coilspacers I.C.E. - Clarion H/U w/ built in monitor, DVD Player, Drop Down, Headrest Monitors, Exterior: - Stock OEM Foglights, Wings West Spoiler, Engine: TRD Drop-In Filter
  4. #3
    Join Date
    Apr 2002
    Location
    Bellingham, WA
    Posts
    9
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Default switch not used
    Simias,
    I'd be curious if someone knows about which company he went with. The company that our dealer uses (Classic Softtrim, http://www.classicsofttrim.com/ ) apparently does not use the switches b/c they're "incompatible" with the heater elements that they install to the seats. They apparently put their own switch on the side of each seat. Problem with that is that it's nice to be able to turn on the passenger seat ahead of time if you're going to pick someone up, but you wouldn't be able to reach the far side of the passenger seat with the button where they put it.
    another nice feature of the stock buttons is that they're a two-step switch (low and high).
    I think the reason CS may avoid using the stock switches is that they'd have to wire into the center console, which would require taking it apart. Another step they don't want to do.
    Any idea how to find the comment from the other TS member?
    thanks for your help.
  5. #4
    Join Date
    Dec 2000
    Location
    Orange County, CA
    Posts
    1,900
    Liked
    0 times
    Rep Power
    16
    sorry dhclark. it was so long ago (early last year) so i don't remember anything other than why he got it done.
    i'll look around on my own and see if i can find anything else as well.
    Chris
    Mods:
  6. #5
    Veteran Member Boone's Avatar
    Join Date
    Oct 2001
    Location
    North Bend, WA
    Posts
    1,007
    Liked
    0 times
    Rep Power
    15
    Default Heated Seats
    I think (and I stress think) that the stock heated seats only operates if someone is sitting on the seat, regardless if the switch is on or not. I tried warming up the passenger seat before my wife got in and she said it was cold, but then heated up as soon as she sat down. Now when it's cold, I turn the button on and put pressure on the seat (so the seat belt sign blinks) with my hand and the seat warms up. Anyone else or I am whacked?!
  7. #6
    Rookie ronhtl's Avatar
    Join Date
    Sep 2004
    Location
    Phoenix, AZ
    Posts
    10
    Liked
    0 times
    Rep Power
    0
    Default back up sensors?
    does anyone know a place in or around phoenix that installs back up sensors?
    2004 Sequoia Limited 4X4, Phantom Gray Pearl, Black Pearl Emblems, Wood grain, Hood Protector, TRD air filter, Amsoil oil 5X30 since day one, Toyota 90915-20004 Japan oil filter. “Toyota: We may not be the fastest off the line, but our stamina will out last the best.”
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
