Headlights do not turn off
+ Reply to Thread
Results 1 to 13 of 13
Thread: Headlights do not turn off
  1. #1
    Join Date
    Apr 2002
    Location
    Philadelphia, PA
    Age
    40
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Unhappy Headlights do not turn off
    Hello all,
    Just yesterday, my headlights refuse to turn off - at all.
    Went to the dealer, they shook their heads. It has a remote starter, so they changed that, suspecting that it messed up the headlights somehow. Did not solve anything. Supposed to come back to the dealer tomorrow. In the meantime, they showed me to unplug a relay to turn it off manually. Hmmmm.
    Has anybody experienced this? Is there a known solution? I'd hate for them to take everything apart.
    Thanks in advance.
    Gil.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member TundraV84Me's Avatar
    Join Date
    Jan 2001
    Location
    So Cal
    Posts
    231
    Liked
    1 times
    Rep Power
    15
    First: is it on auto?
    If it is................is there anything covering the sensors on top of the dash?
    If you turn the swithch to off................do the dash lights turn off?
    Just some questions
    Alex
  4. #3
    Veteran Member Boone's Avatar
    Join Date
    Oct 2001
    Location
    North Bend, WA
    Posts
    1,007
    Liked
    0 times
    Rep Power
    15
    gillygan - I ran into a similar problem. I ended up opening and shutting every door to make sure they were completely closed and I haven't had a problem since. Not sure if that solved the problem or coincidence with something else?! Good Luck!
  5. #4
    Join Date
    Apr 2002
    Location
    Philadelphia, PA
    Age
    40
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Post
    TundraV84Me and Boone;
    All the doors are closed - we double checked on that. That was my first thought - I remembered reading it in the manual somewhere.
    And no, it's not automatic headlights. Manual-R-Us.
    When I switched it to "off" position, the dashboard lights do
    turn off, leaving the headlights and the parking lights on.
    This morning, around 6:30 A.M., I came out to go to work, and the headlights were on (by itself!). I don't know how long it has been on, probably not too long, since the car started with no problem. Headlights did not shut off. I went to have a smoke, and sometime somewhere in the course of 10 minutes, I noticed that the headlights turned itself off. Weird, no? This is quite amusing.
    Off to the dealership again. Maybe they should just give me a new vehicle. heheee.
    Thanks,
    Gil.
  6. #5
    Veteran Member Buzzard's Avatar
    Join Date
    Jan 2001
    Location
    Jones Creek, TX
    Age
    74
    Posts
    1,526
    Liked
    0 times
    Rep Power
    18
    Mine come on when I trigger the auto door lock (off or on). They will come on and go off in a minute or so. Could the problem be in the auto door lock system (if you have one)?---Buzz
  7. #6
    Assistant Administrator nhparrot's Avatar
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    62
    Posts
    6,434
    Liked
    19 times
    Rep Power
    1673
    Sounds like a short in the wiring somewhere, maybe bad relay.
    ~Glenn
    Yes I am a pirate!
    "To err is human. To arrr is pirate."
  8. #7
    Join Date
    Sep 2007
    Location
    Concord
    Posts
    41
    Liked
    0 times
    Rep Power
    8
    Default Re: Headlights do not turn off
    My wife's 2002 is having the same problem. Anyone got a solution???
  9. #8
    Join Date
    Nov 2008
    Location
    Hermitage
    Posts
    250
    Liked
    3 times
    Rep Power
    7
    have you tried swapping the relay that you pull to turn them off? Or possibly a bad fuse in the under hood fuse block feeding the lights
  10. #9
    Join Date
    Sep 2007
    Location
    Concord
    Posts
    41
    Liked
    0 times
    Rep Power
    8
    It started after my wife took it through the car wash on a 2 degree day. I am not going to try anything until it thaws in a few days. If it is still an issue at that point I will check the fuses. Thank you,
  11. #10
    Lurking Member MichaelMr2's Avatar
    Join Date
    Jan 2009
    Location
    Highlands Ranch CO
    Posts
    23
    Liked
    0 times
    Rep Power
    7
    My sequoia does this. I think its a form of daytime running lights. I do notice that If I turn the car off, and cycle the lights through from auto to off and back to auto they shut off. Otherwise they shut off after a few minutes of being parked. its like courtesy light or something.
    I think its intentional.
    RMMOC.com
    Rocky Mountain MR2 Owners Club
  12. #11
    Join Date
    Nov 2008
    Location
    Hermitage
    Posts
    250
    Liked
    3 times
    Rep Power
    7
    Did you find a solution?
  13. #12
    Join Date
    Nov 2010
    Location
    iowa
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    my '06 Tundra is doing the exact same thing...headlights are not going off. Any new thoughts?
  14. #13
    Junior Member cinch's Avatar
    Join Date
    Oct 2010
    Location
    Boulder Creek Ca
    Posts
    182
    Liked
    3 times
    Rep Power
    783
    You need an exorcist.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
