Sun Roof has a rattling Noise at 40+ MPH
+ Reply to Thread
Results 1 to 14 of 14
Thread: Sun Roof has a rattling Noise at 40+ MPH
  1. #1
    Junior Member devillar's Avatar
    Join Date
    Dec 2004
    Location
    Wildwood, Missouri
    Age
    51
    Posts
    85
    Liked
    0 times
    Rep Power
    11
    Smile Sun Roof has a rattling Noise at 40+ MPH
    2004 Toyota Seqoia SR5
    Took to the dealer to perform TSB NV006-04, Title "Moon Roof (Sliding Door) Creak Noise" thinking that this would solve the noise problem that I experienced mostly on the freeway. The dealer wisely discovered when reading this TSB that my VIN# was not effected. However, the dealer lubed, tightened some loose hardware(?), and installed some foam/seals. Now the noise is muffled and not as obvious. However, the noise is still there. I plan on waiting sometime before I take it in again (while still under warranty).
    Anyone have a similar problem with noise coming from the Sun/Moon Roof? Any suggestions for a good fix? In advance, thank you for your comments.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Jun 2004
    Location
    Los Angeles, CA
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Something I've noticed on my '04 Sequoia SR5 is that when I hit about 50 mph with the moonroof fully retracted, I get a really weird sounding airpocket/oscillation inside. It goes away if a lower the liftgate window a bit. Probably not related to your problem, but I found it interesting.
  4. #3
    Join Date
    Dec 2004
    Location
    Wildwood, Missouri
    Age
    51
    Posts
    85
    Liked
    0 times
    Rep Power
    11
    Thread Starter
    Default Sun Roof has a rattling Noise at 40+ MPH
    Something I failed to mention in the original post was that this noise occurs with the Sun/Moon Roof CLOSED>
  5. #4
    Lurking Member ccrews's Avatar
    Join Date
    Dec 2004
    Location
    Bellflower, CA
    Posts
    40
    Liked
    0 times
    Rep Power
    11
    Default oscilating air pocket
    I noticed the same thing with my new '04 SR5. And was quite suprised to find it mentioned in the DVD I got in the mail from Toyota last week. It basically says when you push the button to retract the sunroof, it doesn't automatically go back all the way - to reduce wind noise, but that if you want it fully retracted, then press the button again adn it will continue all the way back.
  6. #5
    Join Date
    Dec 2002
    Location
    Somewhere
    Posts
    78
    Liked
    0 times
    Rep Power
    13
    Anybody know if this effects the 03's (SR5)? Mine just started making a funny noise and does it only intermiitently.
  7. #6
    Join Date
    Oct 2002
    Location
    Gilbert
    Posts
    37
    Liked
    0 times
    Rep Power
    13
    Quote Originally Posted by scottyj33
    My 03 SR5 is making the funny noise too.
  8. #7
    Join Date
    Dec 2004
    Location
    Leesburg, VA
    Posts
    22
    Liked
    0 times
    Rep Power
    11
    Do any of you have a wind deflector... maybe this would help, we just had one installed on our 05 Seq, relatively inexpensive
    2005 Sequoia
  9. #8
    Join Date
    Apr 2002
    Location
    Los Angeles
    Posts
    9
    Liked
    0 times
    Rep Power
    0
    Default Noise
    I can duplicate this noise when...
    driving around 50mph
    sunroof is closed
    sunshade is closed
    back door window is open
    The weird noise is not bearable for any person in the vehicle, the sunshade actually vibrates up and down 5mm.
    Sequoia 2001 SR5
  10. #9
    Join Date
    Nov 2004
    Location
    Vero Beach, FL
    Posts
    26
    Liked
    0 times
    Rep Power
    11
    Default You're not alone
    Got it! It is the only thing wrong so far....
    2000 Black Ltd. TRD 4x4 Access Cab
    Donahoe Coilovers/Camburg Arms, 5100's rear, Hellwig, Dual Exhaust W/50 Flowmaster,, TC Rack Bushings,TC 1" Diff Drop, 265/75/16 Revo's, Pro Comp Alloys/Black, Westin Platinum Series Nerf Bars/Black, ARE Lid, Stock leather & burlwood dash, '05 tail lights
    2003 Phantom Gray Sequoia Ltd 4x2 (stock)
  11. #10
    Join Date
    Dec 2004
    Location
    Wildwood, Missouri
    Age
    51
    Posts
    85
    Liked
    0 times
    Rep Power
    11
    Thread Starter
    Default The Fix The Solution The Answer to this Problem
    The noise was actually discovered at the lower portion of the windshield. Possibly caused by the hood bud deflector. Jay Wolfe Toyota maintenance technician found the left and right external piller moldings loose and removed and insulated behind the trim. Code 61499 T91 T43. This fixed the problem! Outstanding work by Jay Wolfe Toyota in Ballwin, Missouri. Success at last. This was not easy problem to identify. Excellent, job by the dealership!!
  12. #11
    Join Date
    Feb 2005
    Location
    Cumming, GA
    Age
    43
    Posts
    28
    Liked
    0 times
    Rep Power
    10
    Default NV006-04 2004-05-31 NOISE, VIBRATION & HARSHNESS MOON ROOF (SLIDING ROOF) CREAK NOISE
    I have an '03 Limited with 37K and the sunroof creaks terribly. It creaks 100% of the time... open closed etc.. I'm just out of factory warranty. Has anyone performed this procedure? How difficult is it.
    TSB-
    NV006-04 2004-05-31
  13. #12
    Join Date
    Dec 2004
    Location
    Wildwood, Missouri
    Age
    51
    Posts
    85
    Liked
    0 times
    Rep Power
    11
    Thread Starter
    Default Nv006-04 2004
    I read this service bulletin and it is simply replacing a screw. The part number of the screw is identified in the service bulletin. However, you have to remove part of the upper ceiling lining, right paneling, etc. to get to this screw. However, I did not need to have this done and therefore am not knowledgeable of how difficult it is to remove the liner, etc.
  14. #13
    Join Date
    Feb 2005
    Location
    Cumming, GA
    Age
    43
    Posts
    28
    Liked
    0 times
    Rep Power
    10
    Default Sun roof rattle
    I read the TSB also and it seems like it is not a trivial procedure. Sure wish it was still in warranty.
  15. #14
    Join Date
    Dec 2004
    Location
    Wildwood, Missouri
    Age
    51
    Posts
    85
    Liked
    0 times
    Rep Power
    11
    Thread Starter
    Smile Window Side Trim insulated
    The fix for my problem was removing and reinstalling the window trim sides and insulating behind them. I neglected to mention the noise was found on the forward window not the Sun Roof as I had initially thought.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
