Old 01-22-2005, 09:55 PM
ekunst's Avatar
Last Online: 03-18-2005 07:30 PM
ekunst is on a distinguished road.
ekunst's Photo Albums
Default fix for low volume to the rear seats???
Has anyone found a way to boost the volume to the rear speakers on the factory jbl system???(added a subwoofer or more speakers to the rear/trunk area etc) For some odd reason the volume to the rear passengers is much lower. If i had someone sitting in the third row they probably couldnt hear the stereo at all. I have a 03 sr5 with the factory JBL 10 speaker premium system with rear audio controls, no dvd. Any help would be great
Also has anyone found an upgrade for the front door speakers. Crutchfield, etc doesnt list any for the front door??
keepin the rubber side down
(Not linked)
Old 01-22-2005, 11:49 PM
WisteriaVillage's Avatar
Dealer : Longo Toyota
2001 Toyota Sequoia
Last Online: 01-24-2009 05:36 PM
WisteriaVillage is on a distinguished road.
WisteriaVillage's Photo Albums
I had the exact same problem with my 01' Limited, but through this site I found out there was a TSB for this particular issue. I was able to get the rear amplifier replaced using my extended warranty. The difference was like night and day. The rear speakers seriously crank now. Even if there is not a TSB for your 03' model I would have it checked out because I don't think that such low volume in the rear is normal. The good thing is that you must still be under warranty. Good luck.
Old 01-23-2005, 10:31 AM
Dealer : Toyota South
2001 Toyota Sequoia
Last Online: 10-28-2009 04:47 AM
ctedja is on a distinguished road.
ctedja's Photo Albums
Yup, I just got the TSB done on my Sequoia about 2 months ago under extended warranty. New amps definitely makes the difference. Funny how I told the dealer that there is a TSB, however, they insists of ordering the new head unit. After installing the new head unit, of course it did not fixed the problem, so then they order the amps (put the old head unit back into the truck). Nevertheless, after 3 visits my problem was solved.
Thanks
Chris
01 Sequoia Limited 4WD - Gibson stainless tip, Lund bug shield, glass break sensor.
95 Avalon XLS - Clarion CD player, MPC bug shield, Weathertech vent visor, ISR mod.
Both vehicles - NGK iridium, Mobil1 synthetic oil, grease & filter, Performance Friction pad.
Old 01-23-2005, 08:15 PM
ekunst's Avatar
Smile
thanks and just in time. got 1500 miles left on the warranty. this condition has existed since new so i must take advantage asap.
(Not linked)
Old 01-23-2005, 11:47 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Today 06:24 AM
nhparrot's Photo Albums
The AU001-02 TSB referred to by ctedja is not applicable to the '03 model year. Only '01 & '02. But you should still check with your dealer.
~Glenn
Old 01-24-2005, 01:42 AM
2004 Toyota Sequoia
Last Online: 09-05-2009 03:27 AM
vermacelli is on a distinguished road.
vermacelli's Photo Albums
I have a similar problem in my '04 w/JBL, not much could be heard in the 3rd row but that's just because there's no speakers back there. We take a lot of road trips and I get a lot of complaints about not being able to hear movie dialogue from the 3rd row. So I bought a pair of Kicker tweeters and 4x10's over the weekend. I'm planning on mounting the tweeters up high on the b-pillars and the 4x10's in the 3rd row storage pockets which should fit really nicely with a custom plate. With 75 watts rms to each tweeter and speaker, the 3rd row sound should sound better than the front, especially for DVDs. Later, I'm planning on adding a flat Kicker 8" midbass to each rear door panel storage compartment via a custom slim sealed enclosure, has anyone done this, how's the sound? I just don't want to sacrifice any storage space. They should make a Sequoia XL based on the Tundra D.C., anybody agree?
Old 01-24-2005, 07:53 AM
ekunst's Avatar
Unhappy
Bummer to hear no tbs on the low volume. I will still check with the dealer, this condition cant be right.
I would be interested in how Vermacelli's upgrade goes, although I am reluctant to go too far with upgrades. I did upgrade the rear door speakers to 3-way units thinking that it would help, but there was no change in volume and the fit wasnt factory as Chutchfield inicated. Good luck.
(Not linked)
Old 01-24-2005, 09:01 AM
sequoiasoon's Avatar
Dealer : Competition Toyota Scion of Middle Island
2003 Toyota Sequoia,
- Other - 93 Corolla TOTALLED!
Last Online: 11-03-2009 08:17 AM
Images: 8
sequoiasoon is on a distinguished road.
sequoiasoon's Photo Albums
My drop down DVD has a small amp for "wired" headphones I put a small 30 watt amp on it going to 2 speakers (3 1/2") These fit PERFECTLY in one of the 3rd row cup holders. If you ever change your mind the cup holders are a seperate piece that is very easy to replace. A little more mod'ing or cutting and 4" possibly 5" would fit also. You can also seal off the bottom under that area for better base but still allowing storage under it.
Old 01-24-2005, 12:24 PM
Stargazer's Avatar
Dealer : West Coast Toyota
2003 Toyota Sequoia
Last Online: 08-27-2008 12:13 AM
Images: 16
Stargazer is on a distinguished road.
Stargazer's Photo Albums
One of the things I did to compensate was adjust the fade so that when I turned up the stereo for the rear passengers to hear, I didn't kill my ears up front. That really helped.
The living are just the dead on holiday.
2003 Sequioa LTD ~ Phantom Grey (sold): Stargazer's Garage
Old 01-24-2005, 09:27 PM
ekunst's Avatar
Question
I am interested in your speaker addition. Any clue where I can wire these additional speakers as i I dont a dvd, just the rear audio controls package?
(Not linked)
Old 01-25-2005, 10:08 AM
-=tg=-'s Avatar
Dealer : John & Phil's Toyota
2004 Toyota Sequoia
Last Online: 07-21-2009 10:41 PM
-=tg=- is on a distinguished road.
-=tg=-'s Photo Albums
Correct me if I'm wrong, but you could always get some "computer" speakers and plug them into the headphone jack.
-=tg=-
-=tg=-
Old 12-23-2007, 04:00 PM
Dealer : Leesburg Toyota
2001 Toyota Sequoia Beige SR5 4wd
Last Online: 11-14-2009 11:29 PM
Images: 2
jsutton is on a distinguished road.
Send a message via AIM to jsutton Send a message via Skype™ to jsutton jsutton's Photo Albums
Default Re: fix for low volume to the rear seats???
Glenn or others:
I have an '01 Sequoia but everything's out of warranty of course. Can anyone provide the Toyota part number to replace the AMP mentioned in AU001-02 TSB? Mine went out some time ago - no volume basically at all to rear seats - very low.
Is a replacement Toyota amp the best choice/option for this problem?
Thanks.
Old 12-23-2007, 04:37 PM
el_madmaster's Avatar
Dealer : Burdick Toyota
2001 Toyota Sequoia,
- Other - 1988 Nissan 300ZX
Last Online: 07-26-2009 07:56 PM
el_madmaster is on a distinguished road.
el_madmaster's Photo Albums
Dang. Actually I never noticed it as I never sit in the rear, until some buddies told me to crank it when I could hear it just fine up front. I'm well out of warranty but wouldn't mind getting a little upgrade... namely in the bass and rear volume department. For now i'll just resort to fading to the rear.
1988 Nissan 300zx 5sd 71,000 miles
1995 Nissan Pathfinder 4x4 5spd 90,000 miles (sold, frame gone)
2001 Sequoia Limited 4x4 119,000 miles (some electronic issues, manifolds, otherwise solid and not a single rattle woot)
Old 04-13-2008, 01:13 PM
Images: 2
Default Bummer -Four Months and NO reply to my Question
Old 09-21-2009, 09:14 PM
Images: 2
WOW - no help or response to this query in more than a year since posted !
