17" vs. 16" wheels
+ Reply to Thread
Results 1 to 6 of 6
Thread: 17" vs. 16" wheels
  1. #1
    Join Date
    May 2002
    Location
    New Orleans, LA
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    Default 17" vs. 16" wheels
    Realzing that this is probably a stupid question, I ask it anyway. Do the 17" wheels that are offered as part of the alloy wheel package (AG) raise the ride height over the 16" standard or alloy wheeels. I can't figure out if the 17" "wheels" just have bigger rims and a lower profile tire or if the rims are larger with the same or nearly the same profile on the tire as the 16" wheels, and hence higher ground clearance. My principal concern regards off roading and whether the 17's are worth the investment in terms of ground clearance. If they have a lower profile, I would guess that they would not be an improvement for off road situations, but I wouldn't be the one to ask. Otherwise, does the overall ride inmprove any with 17" wheels? If anyone can help me out here it would be a great help. Thanks. Charlie
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supercharged Member dsrtrcr01's Avatar
    Join Date
    Dec 2004
    Location
    Here
    Posts
    2,711
    Liked
    0 times
    Images
    11
    Rep Power
    404
    Wink Same
    The ride should be the same no matter which rim size you get. When it comes to offroad the different rim size makes no difference. I do think it makes the truck a little higher to have 17 because My friend and I have the exact same truck and his is like less then a 1/4 inch taller. Nothing to base a buy off of. Because when you buy your first set of tires you can go to any size and change ride hieght by a little. I would save the money on the 17 and put it aomewhere else because the rim size makes no difference in anything but looks, and tire size you will need to buy in the future.
    '05 Tundra DC TRD 2 WHL: The TOW truck, Spectra Mica Blue, with Kenwood H/U, Kenwood Amp and crossover. Infinity 6010cs, 10" Rockford SUB, 6 disc CD Changer mounted in Center console, SWI-X to retain steering wheel controls, 7" TV with DVD. Tinted Windows, Three chamber Flowmaster, Painted front chrome strip
  4. #3
    Lurking Member TITAN HATER's Avatar
    Join Date
    Jul 2004
    Location
    Chandler, AZ
    Posts
    27
    Liked
    0 times
    Rep Power
    12
    Rim size will make a difference if you want to stay at stock gear calibrated diameter. If you want a bigger rim, then the tire needs to be smaller. If you don't care about staying at the recommended tire diameter then, rim and tire choice will make no difference.
    Meaning, if we compared your 16" wheel on stock 265/70/16, and decided to go with the current stock application of the Sequoia which is, 17" wheel on a 265/65/17, you would lose 5mm of sidewall height. For offroad I think many would rather require more sidewall. That means if you offroad, that might not be the way you would want to go. You do have the choice of adding whatever size tire you want but, you need to make sure how off your speedometer is going to be afterwards.
    I was running the stock 16" on 265/70/16 tire, and just replaced my wheels for another set of 16's on 275/70/16. With the larger tire, my speedometer is going to be off 1 mile per hour. So when my speedo is saying 60, I'm really cruising at 61.
    Hope this helps....
    2013 Tundra Crewmax Bone Stock
  5. #4
    Join Date
    Aug 2002
    Location
    Niagara Falls, NY
    Posts
    279
    Liked
    0 times
    Images
    2
    Rep Power
    17
    Quote Originally Posted by saturnbar
    Do the 17" wheels that are offered as part of the alloy wheel package (AG) raise the ride height over the 16" standard or alloy wheeels?
    Short answer - NO, given factory tire spec. The overall diameter of the two choices should be identical.
    The ride QUALITY will change - hence the off-road vs highway tire choices on same rims.
    Off road goes for more tire sidewall depth, better cushioning of rim.
    Highway goes for stiffer, lower sidewall for lower rolling resistance, more road feel.
  6. #5
    Join Date
    Dec 2004
    Location
    Richmond, VA
    Posts
    13
    Liked
    0 times
    Rep Power
    0
    Here's a great site for seeing the difference that rim and tire size makes.
    www.miata.net/garage/tirecalc.html
  7. #6
    Join Date
    May 2002
    Location
    New Orleans, LA
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks to all for responding, 16's it is. Charlie
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. Wanted pic : 22' wheels on a SQ? anyone has it yet?
    By herbrock in forum Tires and Wheels
    Last Post: 10-14-2006, 10:29 AM
  2. Changed wheels but not spare wheel
    By Preludetundra in forum Tires and Wheels
    Last Post: 06-06-2002, 03:24 PM
  3. I.S. Wheels
    By abrams57 in forum Tires and Wheels
    Last Post: 05-30-2002, 03:28 AM
  4. 18" Boyd Coddington wheels w/ Michelin Pilot LTX's WOW!
    By Champ_87 in forum Tires and Wheels
    Last Post: 04-26-2002, 08:55 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
