Go Back   Tundra Solutions Forum > SUV Forums > 1Gen-Sequoia
Old 05-11-2005, 01:13 PM
daronk's Avatar
Dealer : Rockingham Toyota
2001 Toyota Sequoia
Last Online: 06-22-2009 09:34 PM
daronk is on a distinguished road.
daronk's Photo Albums
Default Rear Latch
I have the rear latch issue right now.
My questions are:
Is this an easy DIY? If so has anyone posted directions (I searched but didn't find)?
Is 69090-08010 the only part that I need?
I haven't seen the hatch yet but my wife says that the handle is just flopping back and forth which tells me that the cable connection is probably busted.
Shop quoted me $85 parts, $185 labor. If they take that much labor am I in for a whole day of rear hatch trouble.
Thanks.
2001 Toyota Sequoia Limited
1999 Saab 9-5 SE V6 LPT
Old 05-11-2005, 10:16 PM
Dealer : Toyota of West County
2005 Toyota Sequoia
Last Online: 06-28-2009 12:41 AM
Steve97TT is on a distinguished road.
Steve97TT's Photo Albums
If you're handy it's an easy DIY. Might as well know how so next time it breaks you can replace the handle very quickly.
Almost undoubtably a rivet holding the spring pivot in the crappy latch handle broke. The cable is fine and it is still connected to the latch handle. (The handle is a crappy part that is used in several Toyota / Lexus SUVs.) Assuming so you'll only need only that one part.
link to my site for some pics showing the hatch apart and the inside view of the handle / cable connection - you might find it useful.
Steve
My questions are:
Thanks.
Steve
2005 Sequoia Limited
2008 Camry Hybrid
1997 Supra Turbo
Old 05-25-2005, 01:57 PM
Dealer : Toyota of Naperville
2001 Toyota Sequoia
Last Online: 10-27-2009 09:16 AM
Heaterswa is on a distinguished road.
Heaterswa's Photo Albums
I finished my rear latch handle replacement last night. The tab on the handle that pushes the mechanism down to unlatch broke on mine. The wife called Saturday afternoon that the rear door wouldn't open. I started taking it apart Sunday afternoon and picked up the handle yesterday from a local Toyota dealer, he charged me $63 at the counter. Sounds like it would be $70 part if the service dept was doing the job.
First, take off the license plate.
Since the hatch wouldn't open, I started from the inside and took down the top trim piece. After that the two side pieces come down, then the main trim piece which covers the bulk of the door comes out. These are all popped in with the white tabs.
There are 3 access hole covers to pop out (don't forget to install them back in when done) and through the left hole you can see the mechanism to unlatch, press it down with a screwdriver and open the door. If anytime you close the door you will have to do this to unlatch, up until you disconnect the cable and pull out the handle, then you have to locate the cable and pull that directly.
Behind the large trim piece you will find a metal access cover, remove the 7 or 8 10mm bolts holding that on and pop the 3 white tabs and let it hang off to the side. Disconnect the cable from the handle assembly by reaching in from the right hand side and popping of the cable from the handle assembly.
From the left and right access holes, locate the two 10mm nuts which hold the license plate assembly to the door and remove them. Then there are 4 plastic tabs that come in from the outside that hold the license plate assembly on in each corner, try and locate those and using some pliers squeeze them together and push it through. Next locate the license plate lamps wire connector and release that from the left side, it’s the simple push in and pull out square white connector.
After these are out, put back in 1 or 2 bolts into the large metal access cover so the hatch can be lowered (don’t close it).
Here is where I had fun, begin to pop out the assembly that it was bolted to. I ended up breaking 3 of the 4 plastic tabs in each corner because I did not use pliers from the other side to pull them out, however it remained somewhat useable (hindsight 20/20).
Now the license plate assembly can be taken to a bench to replace the handle assembly (Toyota doesn't sell just the handle, it is a small assembly). Two screws out and the assembly is replaced.
Before pressing the license plate assembly back onto the truck, make certain all the plastic tabs are in the assembly and not in the truck. Reverse the process to re-install.
-Bryan
Old 08-18-2006, 10:46 PM
Last Online: 06-04-2007 06:32 PM
jhchang is on a distinguished road.
jhchang's Photo Albums
Default Re: Rear Latch
Heaterswa was right on.
The fix took about 2 hours and is simple for any DIYer. Would highly recommend changing yourself and avoiding the dealer run around. Part cost is about $60.
Old 08-28-2006, 12:07 AM
Dealer : Toyota of Hackensack
2001 Toyota Sequoia
Last Online: 01-29-2008 09:11 AM
nikos is on a distinguished road.
nikos's Photo Albums
It is amazing. Almost every 2001 has gone through a latch. I thought I was lucky and my turn came up last month.
Alternative fix.
I basically did exactly what Byran did in his instructions, however I did not purchase a new latch. I did not want to go through breaking another one (which will happen ) and going at it again. I glued the neck part of the latch with Gorilla Glue. After 24 hours of cure time, I used a metal / plastic weld adhesive that cures like steel. I made a form around the neck and filled it with the weld adhesive. The neck of my latch is now twice the size. There is now way it will break. I also used waterproof marine grease on all the moving parts to ensure friction-less motion ( before I buttoned everything up ).
Extremely poor design by Toyota. I also think that there is a TSB about this issue.
Regards
Nikos
Old 09-05-2006, 11:43 AM
Dealer : Herb Chambers Toyota of Auburn
2002 Toyota Sequoia,
2005 Toyota Matrix XR - Dark Blue
Last Online: 03-21-2007 03:22 PM
pseqmat is on a distinguished road.
pseqmat's Photo Albums
Just completed this repair on my Sequoia. Thanks for the info Bryan. Your instructions were very thorough and greatly simplified the task!!
Old 09-21-2006, 09:31 PM
Dealer : J. Pauley Toyota Scion
2006 Toyota Sequoia
Last Online: 01-09-2009 10:25 PM
suprarunner is on a distinguished road.
suprarunner's Photo Albums
Mine is an 06 and broke 2 days ago, this has me worried about what will start to break after a few more years.
Old 12-25-2006, 08:05 AM
Dealer : Phil Meador Toyota
2001 Toyota Sequoia
Last Online: 01-25-2008 04:16 PM
GreenDrake is on a distinguished road.
GreenDrake's Photo Albums
My 01 just broke yesterday, I'll be giving this fix a shot next week. Damn the cold weather.
Old 07-10-2007, 02:23 PM
Dealer : Dublin Toyota Scion
1997 Toyota 4Runner
Last Online: 01-24-2009 08:58 PM
stinger44 is on a distinguished road.
stinger44's Photo Albums
I have the same problem with the rear door not opening and the handle flaps around like it broke.
Can someone confirm the part number that I need for my 2001 sequoia?
Also are there any websites that have the part cheaper or is the $63 that the dealer charges a safe bet?
Thanks for the help.
Old 07-13-2007, 04:03 PM
Dealer : Downtown Toyota Scion of Spokane
2001 Toyota Sequoia
Last Online: Yesterday 01:19 AM
GeCJ7 is on a distinguished road.
GeCJ7's Photo Albums
Also, don’t forget to really clean out the existing latch mechanism. When I replaced my rear latch handle the latching mechanism was also sticking making it hard to close the hatch. You practically had to slam it shut in order it to latch. Saturate a lot of degreaser or WD 40 to flush out all the rear road gum that has accumulated over the years. Than spay and saturate silicone lubricant. Closing the latch now is like night and day. Know all I have to do is gently drop the hatch and it closes nicely!
Old 07-14-2007, 05:39 PM
Dealer : Shelor Toyota
2001 Toyota Sequoia,
2006 Toyota Tacoma 4x4, TRD OR, tow pkg
Last Online: 10-17-2009 03:37 PM
neffster is on a distinguished road.
neffster's Photo Albums
Subscribing so that if/when mine breaks I'll have an easy way to find the DIY instructions.
2006 Silver Streak Mica Tacoma- 4x4, TRD-OR, DC, Auto, Tow Package, OEM Tube Steps, Donohoe Racing Coil Overs, Light Racing UCA's, Rear Leaf and tailgate TSB's.
2001 Natural White Limited Sequoia - Viper 5500 SST, Garmin Nuvi 680 and Sylvania Silverstars (for the misses)
Old 07-24-2007, 04:09 PM
Dealer : Dan Cava's Toyota World
2003 Toyota Sequoia SR5,
- Other - 1972 FJ-40
Last Online: 03-03-2009 03:07 PM
OHIOFJ40 is on a distinguished road.
OHIOFJ40's Photo Albums
Steve
I know this is kind of old, but does anyone have these pics, or some new pics of the internals of the hatch?
My rear latch doesn't seem broken, but the hatch won't open, no matter what I do or how hard I pull on it.
Old 08-05-2007, 07:15 PM
Last Online: 12-22-2008 12:17 PM
94SupraTT is on a distinguished road.
94SupraTT's Photo Albums
Mine broke a few days ago. Looks like its time to fix it.
Rico
1994 Toyota Supra (single turbo)
1997 Mazda Millenia (married into this car)
2001 Toyota Sequoia
Old 08-18-2007, 04:27 PM
Dealer : Perry Motors
2001 Toyota Sequoia
Last Online: 06-15-2009 09:33 PM
mbz300cd is on a distinguished road.
mbz300cd's Photo Albums
Default Thank You!!!
Just finished this repair. THANK YOU for the tips! It would have been quite a challenge without them. It only took an hour for the whole job. I was able to open the hatch using one of those 90 degree screwdrivers. I got it into the hole and felt around for the mechanism and got it to open. One thing I hadn't read or maybe I just missed it was about removing the pull-down strap. The cover for the bolt comes off easily by pushing upward on it to expose the 10mm screw/bolt. Additionally, there sure is a big difference from dealer to dealer on priceing. I checked three different dealers for the best price for the part, one was $74, one $76 and the one I bought was $63.
Old 09-03-2007, 04:54 PM
tshirt_n_jeans's Avatar
Dealer : Star Toyota
2003 Toyota Sequoia Horse/Kid Hauler,
2002 Toyota Tundra Fire Truck,
- Other - 76 Celica GT - RIP
Last Online: 11-04-2009 11:55 PM
tshirt_n_jeans is on a distinguished road.
tshirt_n_jeans's Photo Albums
Thumbs up Re: Rear Latch
Mine broke today.
What a PITA.......
If your handle is just flopping around, its because the latch handle broke. It is only a very small piece of plastic and I am shocked that mine lasted 4 years....
THANKS for all the tips. I will head to the dealer tomorrow for the parts.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/1gen-sequoia/40507-rear-latch/
Posted By For Type Date
CanadianDriver: Used Vehicle Review - Toyota Sequoia, 2001-2007 This thread Refback 01-23-2008 10:06 PM
Rear window latch broken bluetundra Interior & Exterior 9 08-29-2008 07:56 PM
Broken Rear Window Latch! 2DaMax Interior & Exterior 21 04-03-2007 08:14 PM
rear door window latch broken Tundrav8yamaha Interior & Exterior 8 03-26-2007 04:03 PM
rear latch problem Steve97TT 1Gen-Sequoia 3 02-28-2005 04:57 AM
Rear slider latch broken rgreed Interior & Exterior 10 08-20-2004 12:30 PM
