Old 07-06-2005, 11:47 PM
Last Online: 07-29-2005 08:44 PM
monseq is on a distinguished road.
monseq's Photo Albums
Default Gas pedal problem???
does anyone experienced a problem with gas pedal not giving gas? I'm depressing the pedal all the way down just to give enough gas to move my 2001 SR5 4wd. besides VSC/TRAC, ABS, Check engine lights are all on, I had it scanned and the code read C1203. The mechanic inspected everything but didn't find any apparent fault. We are suspecting on the throttle or ECU. Any ideas why it's happening.
Old 07-07-2005, 12:51 AM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
When C1203 comes up by itself, it usually meaNS TO CHECK YOUR BRAKES AND THE BRAKE FLUID LEVEL
tHE LACK OF THROTTLE RESPONSE IS USUALLY THE THROTTLE PEDAL POSITION SENSOR. It found on the passenger side of the throttle body
25 yrs with TOYOTA
Old 07-08-2005, 03:27 AM
Can the throttle pedal sensor affect performance of the pedal? We had the throttle installed on another vehicle it worked just fine. Could there be some ECU software problem that restrains gas flow. Can it be reset or something.
Old 07-08-2005, 09:13 AM
Last Online: 10-30-2009 05:06 PM
Images: 2
pcosens is on a distinguished road.
pcosens's Photo Albums
Originally Posted by monseq
. . . besides VSC/TRAC, ABS, Check engine lights are all on, I had it scanned and the code read C1203. . . .
I'd be willing to guess that the throttle issue is merely a symptom of a much different problem. You could always try disconnecting the battery and allowing the truck to sit for 1/2 hr to clear all electronic system memories, ECUs, etc. Reconnect the battery and all systems start afresh (hopefully). BEWARE - this could also kill the system for good!
That's an old IT consultants trick - if all else fails just re-initialize all electronics - the vehicle MAY have just "dropped a zero" and locked up.
Good luck, keep us posted!
Paul
Gas Quality and Fuel Injector Life. Verndog Engine & Drivetrain 10 08-16-2009 01:49 PM
Attn Trippers and Offroaders: do you carry extra gas? breakmark Off-Roading 48 08-26-2006 10:05 PM
Do I have a tranny problem? jfranciskay Engine & Drivetrain 5 12-12-2003 10:01 PM
Audio system problem TetTundra Audio & Stereo 5 11-08-2003 02:23 PM
gas damage paint?? Joon Interior & Exterior 7 09-23-2002 01:37 PM
