Old 07-24-2005, 03:54 PM
gnb gnb is offline
2002 Toyota Sequoia
Last Online: 10-05-2009 04:47 PM
gnb is on a distinguished road.
gnb's Photo Albums
Default 2002 Sequoia- Another Broken Door Handle
Whatzup with Toyota's QA/QC on its door handle parts !
A year ago the inside door latch on the driver's side busted apart in my hand.
Last month the exterior tailgate PLASTIC latch broke .
Today I noticed the passenger side rear door's inside plastic latch is cracking.
Very dissapointed in the quality of material Toyota has used on our Sequoia. Hopefully, not the case on the drivetrain parts.
Anyone else seeing these problems? Is there a DIY for the inside latches replacement posted anywhere here?
Sorry for venting- but this is not the Toyota quality that I am used to.
Old 07-25-2005, 09:33 PM
gnb gnb is offline
2002 Toyota Sequoia
gnb's Photo Albums
Default Help Bump!
Common Guys - I have the new inside handle to replace my broken one.
I've gotten the center screw out - but the inside rear passenger latch bezel will not come out.
What the trick? I see no other fasteners and I hate to use force for fear of breaking it.
Old 07-25-2005, 11:07 PM
Chinee's Avatar
Dealer : Ed Morse Delray Toyota Scion
2002 Toyota Sequoia
Last Online: 11-05-2009 11:44 PM
Chinee is on a distinguished road.
Chinee's Photo Albums
I saw this last week when searching for hints to replace a broken side mirror (wife strikes again).
hi guys....just an FYI to remove the door handle surround/insert if its like the lexus, tundra...look between the top of the lock button above the door handle and the plastic insert surrounding it...u will see a slight indentation inside there...push a small flatpoint screwdriver up there between the locking button and the insert and the top of the insert will pop out..sometimes u have to do the same to the bottom of the insert between the door handle and insert...
... from Kevin7909
Old 08-01-2005, 01:23 AM
Last Online: 08-06-2005 05:37 AM
BillG is on a distinguished road.
BillG's Photo Albums
I have had both front door handles replaced under warranty. Now I'm out of warranty, so I'm sure they will break again soon. I love my Toyota, but the handles are very sub-standard.
Old 08-01-2005, 01:43 AM
Simias's Avatar
Dealer : Carson Toyota Scion
2001 Toyota Sequoia 2WD SR5,
2004 Toyota 4Runner 4WD V8 Sport
Last Online: 10-25-2009 11:18 AM
Simias is on a distinguished road.
Simias's Photo Albums
gnb...sorry for the late reply, but if you haven't figured out how to pull off the bezel check out this link: http://www.tundrasolutions.com/forum...ad.php?t=36222
the instructions and pix will help you get it off. worked for me a few months back when i had to pull the whole panel off. hope this helps!
Chris
Old 08-01-2005, 09:55 PM
gnb gnb is offline
2002 Toyota Sequoia
gnb's Photo Albums
Chris
Cannot tell from the diagram - Do you have to remove the entire door covering ? Or can you replace the inner door latch after removing the plastic bezel?
Old 08-02-2005, 04:51 PM
Chinee's Avatar
2002 Toyota Sequoia
You've got to remove the entire door panel before changing out the latch... (i.e. if I remember correctly).
Old 08-14-2005, 10:41 PM
Dealer : Atlanta Toyota
2004 Toyota Sequoia
Last Online: 11-04-2007 08:03 PM
mmvv is on a distinguished road.
mmvv's Photo Albums
These Sequoia door handles are the same as the Lexus LX and GX 470.
Old 08-28-2005, 07:58 AM
tiger's Avatar
Dealer : Beaman Toyota Co.
2005 Toyota Tundra,
2008 Toyota Highlander HV
Last Online: 06-16-2009 08:25 AM
tiger is on a distinguished road.
tiger's Photo Albums
Default 02 Sequoia
We have replaced the door handle on the 02 Seq before & its starting to feel the same right before it cracked! For some reason when you get out the door lock is in the locked postion, safety feature, and when you pull the handle it has a catch to it, your basically pulling harder to open the dang door. It's not smooth when you pull the handle. Now when you unlock the door before opening you don't have to pull as hard to open the door. It's a minor thing but done several times a day for years & well you've got too many door handles bustin! Yea we have the same problem
Old 08-28-2005, 04:37 PM
Chinee's Avatar
2002 Toyota Sequoia
Why don't you change the programming so that the doors unlock when you put the tranny in "P"ark? That should alleviate much of the stress and you handles should last a little longer... they will still break, just not as quickly.
Old 08-30-2005, 10:01 AM
tiger's Avatar
2005 Toyota Tundra,
Default humm
How excatly do you do that? Haven't come across that solution yet thanks!
Old 08-30-2005, 09:20 PM
Chinee's Avatar
2002 Toyota Sequoia
You can search the site, but it will be far easier to check page 14 in our owner's manual. It was one of the first settings I changed when I got the truck, and I followed the instructions in the manual.
Old 08-31-2005, 06:02 PM
tiger's Avatar
2005 Toyota Tundra,
Default Sweet
As much as I've looked through the manual you would think I would have noticed. Cool, thanks for the info
Old 12-12-2006, 02:51 PM
AOK AOK is offline
Dealer : Toyota of Glen Burnie
2003 Toyota Sequoia
Last Online: 11-29-2007 03:34 PM
AOK is on a distinguished road.
AOK's Photo Albums
Default Re: 2002 Sequoia- Another Broken Door Handle
Hi Everyone,
I just saw this forum on google because I am trying to fix my interior door handle/lock on my 2003 Toyota Sequoia. Does anyone know where I can get this part please? Its frustrating trying to get out the door and having to wind the window down and get out that way.
I really need to find where this part is carried, what the technical name is called and where I can buy it and fix it.
Old 12-12-2006, 07:57 PM
Dealer : Toyota City
2004 Toyota Sequoia
Last Online: 07-26-2009 09:42 PM
wipp is on a distinguished road.
wipp's Photo Albums
I reprogrammed mine as well - it now unlocks as soon as it is placed in park. Directions in the manual.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/1gen-sequoia/43535-2002-sequoia-another-broken-door-handle/
Posted By For Type Date
CanadianDriver: Used Vehicle Review - Toyota Sequoia, 2001-2007 This thread Refback 01-24-2008 01:40 AM
2002 Toyota Sequoia OEM Service Manual in .pdf bretbowman Audio & Stereo 10 10-31-2009 01:14 PM
Driveline vibration. nhparrot Engine & Drivetrain 5 01-23-2009 04:21 PM
Which BRAND of OIL? nhparrot Engine & Drivetrain 9 10-29-2007 01:43 PM
New Plugs nhparrot Engine & Drivetrain 1 10-21-2006 01:14 AM
2002 Sequoia @WD- Best Replacement Shock Options gnb Suspension & Axle 5 10-08-2004 02:12 PM
