Fuel level sensor malfunction?
+ Reply to Thread
Page 1 of 3 123 LastLast
Results 1 to 15 of 37
Thread: Fuel level sensor malfunction?
  1. #1
    Junior Member toyotafreak's Avatar
    Join Date
    Nov 2003
    Location
    Corona, CA
    Posts
    98
    Liked
    0 times
    Rep Power
    12
    Default Fuel level sensor malfunction?
    Our fuel level indicator seems to have gotten a tad buggy in the last few months. We're at 45K on the '03 Sequoia SR5.
    The first instance was when I had started the engine and the fuel needle wavered and then dropped to where like negative 1/2 tank might be. Way down off the scale. It stayed there, so I just turned the truck off for a second and restarted - the indicator started that low but then worked its way back up to where it should have been. Very strange in itself, but wait...there's more!
    It seems as though since that time, a full tank sits on the other side of the full line than it used to. Almost like how when your truck's loaded it displays a different amount of fuel. Wierd but not a biggie.
    Finally, this weekend, on the final part of a 170-mile run, the indicator slowly drained from 1/4 tank to near empty (with the low-fuel light coming on) over the course of ten or twenty minutes. While I was rushing to get home to see Desparate Housewives and wondering if I was going to make it the final 20 miles without stopping for gas, traffic loomed up ahead and I had to jump on the binders. Lo and behold, at that very instant, the fuel light extinguished and the fuel level returned up to 1/4 tank. After getting home and then filling the next morning, it's clear that there was actually 1/4 tank in there at the time.
    This is sounding more like a fuel level sendor/sensor issue, doesn't it?
    2003 TOYOTA Sequoia SR5: 89K, TRD cat-back, fueled by Chevron; M1 oil/filter
    2000 TOYOTA Epic S22: Powered by Lexus 1UZ w/VVTi, Chevron/M1
    1995 TOYOTA Hilux: 206K, any gas, any filter, first 100K Castrol Syntec, GTX since
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Feb 2002
    Location
    New York (Mid -state)
    Posts
    67
    Liked
    0 times
    Rep Power
    14
    Had the same issue on my 01 sr5. fill the tank, and the gage reads empty, but the overhead computer says 400 MTE.
    I had the extended warranty on the truck, so it didn't cost me anything. had 55k on it. Took them a few hours, as they had to drop the gas tank to get at that sensor.
  4. #3
    Join Date
    Feb 2005
    Location
    Cumming, GA
    Age
    44
    Posts
    28
    Liked
    0 times
    Rep Power
    11
    My did the same exact thing 2 weeks ago. Strange.
  5. #4
    Join Date
    Nov 2002
    Location
    Moyock, NC
    Age
    51
    Posts
    51
    Liked
    0 times
    Rep Power
    13
    Quote Originally Posted by mechengr
    I have the same problem with mine. Thinking of doing it myself, drop the tank and replace the sensor.
    2006 Dodge Ram 3500 5.9 CTD SRW 4x4 13,600 miles
    2005 Toyota Camry XLE 33,00 miles
    2002 Toyota Sequoia 2wd Limited. 90,000 miles.
    2002 Suzuki Katana 15,500 miles motorcycle
    2001 Toyota Avalon XLS. 78,600 miles.
    1992 Toyota Previa. 140,000 miles.
    1997 Acura Integra LS 106,000 miles.
    1990 Dodge Dakota 3.9L V6. 110,000 miles.
  6. #5
    Join Date
    Nov 2003
    Location
    Corona, CA
    Posts
    98
    Liked
    0 times
    Rep Power
    12
    Thread Starter
    Wife reported that she watched the fuel needle drop well below empty and she had the sense to check the DTE indication above...it still read 70-something miles to empty. I figured that the DTE would be like AVG MPG times fuel remaining, and if so....then the fuel level sensor was operating just fine and the dash indicator was hosed.
    Wonder what gives there. Maybe will have them explain when we take it in for the knuckle recall.
  7. #6
    ab
    ab is offline
    Supporter ab's Avatar
    Join Date
    Feb 2003
    Location
    Vancouver Island
    Age
    46
    Posts
    304
    Liked
    3 times
    Images
    5
    Rep Power
    19
    Same problem with my 00 Tundra, fixed under 3yr. warranty
    [SIZE="1"]00 TUNDRA V8 AC LTD / 03 SEQ LTD / 05 TUNDRA V6 Longbed (2) / 06 TUNDRA DC / 07 TACO DC / 93 Mr2 Turbo / 87 MR2
  8. #7
    Join Date
    Nov 2005
    Location
    new jersey
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    my 04 had this problem. used to park overnight, get in the next morning and would show empty. over 20mins of driving, the needle would very slowly creep up to the right level
  9. #8
    Join Date
    Nov 2002
    Location
    Moyock, NC
    Age
    51
    Posts
    51
    Liked
    0 times
    Rep Power
    13
    Quote Originally Posted by bauerb
    Are you planning to fix this yourself? I read one of the post says the fuel sensor need to be replaced. I'm going to order the sensor today and replace the sensor this weekend.
  10. #9
    Join Date
    Nov 2005
    Location
    Houston, TX
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Had same problem with my 03 Sequoia at 47K. Dealer replaced the fuel sender gauge assembly. From the posts on this thread, I would say Toyota needs to do a recall.
  11. #10
    Join Date
    Feb 2002
    Location
    Atlanta
    Posts
    10
    Liked
    0 times
    Rep Power
    0
    Default Re: Fuel level sensor malfunction?
    Mine is doing the same. 2003 Sequoia Ltd with 36K miles..Sucks for me.
  12. #11
    Supporter Agent 409's Avatar
    Join Date
    Sep 2002
    Location
    Arizona
    Posts
    780
    Liked
    6 times
    Images
    39
    Rep Power
    879
    mine has done the same on a handful of occasions and the dealer said that they would have to recreate the problem. if it doesn't consistently do it, i'm screwed. thats retarded.
  13. #12
    Supporter ccf15's Avatar
    Join Date
    Nov 2006
    Location
    Southern Arizona
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    My '03 Limited with 47k on it has been having fuel guage problems also. This has occured five times in the last six months. I will start it up and the guage will be on E with the Low Fuel light on (actual fuel level in tank does not matter) but the Trip Meter refelecting the actual available fuel. After a period of time driving, the guage will slowly creep up to the real fuel level.
    The dealer gave me a similar line saying that they need the truck at the dealership to diagnose the problem. I don't normally make it a habit of hanging around the dealership waiting for a problem to arise.
  14. #13
    Join Date
    Sep 2002
    Location
    Arizona
    Posts
    780
    Liked
    6 times
    Images
    39
    Rep Power
    879
    mine has been doing it consistently every tank now at a certain amount of fuel left. the problem is that it'll happen once, and if the dealer needs to see it they prob won't. i don't want them to drive my truck around and waste an entire tank of gas to fix it. its still my dollar. punks.
  15. #14
    Join Date
    Nov 2006
    Location
    Upstate, NY
    Posts
    17
    Liked
    0 times
    Rep Power
    0
    My 04 ltd just started this weekend...I figured it was just the sub zero temps b/c as I drove it around, the level went up. Talked to guy with an 01 and he had same prob last year....i'm a little over my warranty (90K) so I may just not worry about it unless wifey notices it
  16. #15
    Join Date
    Sep 2002
    Location
    Arizona
    Posts
    780
    Liked
    6 times
    Images
    39
    Rep Power
    879
    i still haven't fixed mine..bugs the crap out of me. but the dealer has to see it to believe it. and since it happens about 2-3 times a tank that limits the times that i am right next to my dealer at that moment to drive over there and prove it. and i'm not gunna let them joy ride it to find it and waste my tank.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. Whay is 14.7:1 air fuel not important in a Diesel?
    By Agent WD-40 in forum Engine, Intake, Exhaust, Induction
    Last Post: 08-22-2011, 10:00 PM
  2. Fuel Filter: How to replace and is it hard?
    By nhparrot in forum Engine, Intake, Exhaust, Induction
    Last Post: 05-23-2010, 08:21 PM
  3. Fuel Gauge Issues?
    By nhparrot in forum Electrical & Computer Systems
    Last Post: 11-12-2006, 02:56 PM
  4. Replies: 20
    Last Post: 08-30-2004, 05:00 PM
  5. Rocket fuel?
    By glenhaven in forum Engine, Intake, Exhaust, Induction
    Last Post: 08-14-2004, 09:48 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
