  #31 (permalink)
Old 11-06-2007, 11:16 AM
dr427's Avatar
Dealer : Hudiburg Toyota Scion
2003 Toyota Sequoia
Last Online: 05-31-2008 12:26 AM
dr427 is on a distinguished road.
dr427's Photo Albums
Default Re: Rear Window Dead?
I fixed mine with a right door window motor off ebay. I took the gear out of the old rear window and replaced it with the salvaged one I got off ebay and works great! Really wasn't difficult at all. Had I been thinking I would have taken pictures of the step by step process, but it really wasn't difficult at all.
  #32 (permalink)
Old 11-12-2007, 10:59 AM
Last Online: 01-10-2009 10:42 AM
Tripower455 is on a distinguished road.
Tripower455's Photo Albums
Well, my wife's fixed itself while I was printing out the tsb!
Thanks guts......
Where is the fuse for this thing. There are no fuses where the manual says it is.
  #33 (permalink)
Old 11-20-2007, 12:45 PM
Dealer : Toyota of Knoxville
2005 Toyota Sequoia
Last Online: 10-05-2008 11:39 AM
tcltoyota is on a distinguished road.
tcltoyota's Photo Albums
Had the same problem twice on my 2005 Sequoia. Rear window, wiper and defogger all dead. First time it was repaired under warrenty (29,000 miles) about a year ago. This time I have 45,000 miles (althought only 29 months old) and the service center quoted $650 to repair, at my cost. Both times they say the window motor shorted out and ECU for the window shorted out as well. That part (the ECU) alone they quoted as $219. I did not get it fixed. I read through the Techncial Service Bulletin EL007-06 and it sounds like a lengthy process, especially drilling out the rivits. However, from reading above, it looks like the process will fix the root cause. I'd like to know if anyone has approached Toyota with this common design flaw issue and had a positive response from them, i.e., they would help defer the cost of fixing their design error.
  #34 (permalink)
Old 07-23-2008, 11:34 AM
Dealer : Russel Toyota
2005 Toyota Sequoia
Last Online: 07-10-2009 12:35 PM
duecedog98 is on a distinguished road.
duecedog98's Photo Albums
I own a 2005 Toyota Sequoia and have the same problem. The rear window will not go down. I took it into the dealer and they said that the rear window motor and the ECU would have to be replaced. The total cost would be $845.00. The breakout of the price is as follows: $323.77 for the motor (part # 85710-00070), $258.06 for the ECU (part # 89222-00020) and $2.56 for two rivets (part number 90269-05035). There would also be 2.0 hours of labor.
Has anyone else been quoted a price this high? Also, does anyone know where I can go to order the parts myself?
  #35 (permalink)
Old 07-24-2008, 02:22 PM
sequioapower's Avatar
Dealer : Coggin Toyota Scion of the Avenues
- Other - 2001 Jeep Wrangler,
2007 Toyota Tundra Slate 4X4
Last Online: Today 05:09 AM
Images: 3
sequioapower is on a distinguished road.
sequioapower's Photo Albums
I posted this awhile back, but I have an 02 Sequoia and my rear motor died about 3 years ago. I purchased a motor off ebay from a 4Runner because those motors are manufactured in Japan and there have been less reports of failures. The whole thing cost me about $25.00.
2007 4x4 Limited Slate Metallic Tundra
Bilstein 5100 w/2" lift Front
Bilstein HD Shocks Reat
Navigation.
XM
Moonroof
Grey Leather.
Rhino Lined bed
Smittybuilt Side steps
Toyota/Bushwacker fender flares
Painted body side molding
Magnaflow Cat-Back Exhaust
Extang Tonneau Cover
  #36 (permalink)
Old 08-14-2008, 07:19 PM
Dealer : Claremont Toyota Scion
2005 Toyota Sequoia
Last Online: 08-14-2008 07:19 PM
milespergallon is on a distinguished road.
milespergallon's Photo Albums
I just went to the dealer today. I mentioned that my rear window wouldn't go down. Toyota apparently has a bulletin out on this problem and the rear motor and ECU were replaced free of charge even though my '05 LTD was out of warranty. Not bad!!!
  #37 (permalink)
Old 08-17-2008, 06:19 PM
Dealer : Stone's Town & Country Toyota
2003 Toyota Sequoia
Last Online: 08-17-2008 06:42 PM
spuddy is on a distinguished road.
spuddy's Photo Albums
So what exactly goes wrong with the motor? We just bought an 03 sequoia and didn't discover until we got home that the rear window doesn't move. It sounds like a common problem.
  #38 (permalink)
Old 08-17-2008, 08:54 PM
Dealer : Gateway Toyota
1994 Toyota Camry,
2004 Toyota Sequoia
Last Online: 11-14-2009 04:43 PM
Andy4 is on a distinguished road.
Andy4's Photo Albums
try this posting for your window problem.
look at the TSB.
Rear Window, Defrost, Wiper not working
  #39 (permalink)
Old 08-19-2008, 06:11 PM
Dealer : Power Toyota Irvine
2005 Toyota Sequoia
Last Online: 09-04-2008 11:59 PM
iamanirvanafan is on a distinguished road.
iamanirvanafan's Photo Albums
Mine is the same thing dead. I did replace the handle in the back a few months ago and it worked for a little while after that. It could be a loose wire. Everything I have been finding on this problem sounds like 2 things bad motor or a loose wire. Dealer will charge you an arm and a leg and maybe 1st born.
  #40 (permalink)
Old 08-19-2008, 06:29 PM
2005 Toyota Sequoia
penntl
My GarageDealer : Haley Toyota
2006 Toyota Sequoia
Last Online: 04-02-2008 04:48 PM
Re: Rear Window, Defrost, Wiper not working
Had the same problem; here's what fixed mine. It appears that the window motor some how got into a bind. I removed the rear panel. Remove screws from rear hatch access panel. There is a plate with four screws that hold the window motor. I loosened these screws and lightly wiggled the panel while my son was inside pressing the switch in the down position. The widow and wiper now works! Hope this helps.Wonder what the dealer would have charged for such a fix?
  #41 (permalink)
Old 09-13-2008, 12:22 PM
-=tg=-'s Avatar
Dealer : John & Phil's Toyota
2004 Toyota Sequoia
Last Online: 07-21-2009 10:41 PM
-=tg=- is on a distinguished road.
-=tg=-'s Photo Albums
30 mintues for me to fix according to the TSB on my 2004, just removed the spring.
It seems that you can probably remove the spring w/o removing the regulator or disconnecting any of the electrical (although, I do suggest removing the negative on the battery...just in case).
If I would have only done that, I think the process would have been 5 minutes.
-=tg=-
  #42 (permalink)
Old 09-15-2008, 10:25 PM
Dealer : North Point Toyota Scion
2004 Toyota Sequoia
Last Online: 10-16-2009 10:50 AM
jxhopper is on a distinguished road.
jxhopper's Photo Albums
Removed all parts per TSB on my 2004. Window works perfectly now!
  #43 (permalink)
Old 09-22-2008, 09:37 AM
Dealer : Rolling Hills Toyota Scion
2003 Toyota Sequoia
Last Online: Yesterday 09:38 AM
M in KC is on a distinguished road.
M in KC's Photo Albums
Ditto to jxhopper. My '03's rear window wouldn't go down with 65K on it. Rear wiper worked, rear defrost worked just no up/down. I could hear the motor trying to operate when I would depress the up/down button so I was fairly confident my motor and ECU were good. 20 minute job for those still on the fence. Leave the whole regulator assembly in the back hatch and just remove the parts listed in the TSB.
  #44 (permalink)
Old 09-28-2008, 11:47 AM
2005 Toyota Sequoia
Last Online: 09-28-2008 12:13 PM
Falk is on a distinguished road.
Falk's Photo Albums
Thanks Andy for the TSB. I will give it a try this week.
  #45 (permalink)
Old 10-25-2008, 06:24 PM
Dealer : North Park Toyota of San Antonio
2001 Toyota Sequoia
Last Online: 03-02-2009 08:37 PM
dwatts is on a distinguished road.
dwatts's Photo Albums
Thank you. I removed the spring and the stop (attached by two bolts) and my rear window works again. I only needed to remove the plastic covers and the one plate that holds the ECU to get to it. 10 minutes of work and 2 hrs of nerve to do it.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/1gen-sequoia/47400-rear-window-dead/
Posted By For Type Date
CanadianDriver » Toyota » Used Vehicle Review: Toyota Sequoia, 2001-2007 This thread Refback 05-30-2009 04:28 PM
CanadianDriver: Used Vehicle Review - Toyota Sequoia, 2001-2007 This thread Refback 01-23-2008 10:14 PM
Extended Cab rear quarter window hinges breaking Brian's Toy Interior & Exterior 13 03-26-2007 04:00 PM
Rear Power window ricqik 4Runner 6 03-12-2006 06:41 PM
Installing a rear window defroster on a shell? imjin Electrical & Computer Systems 1 05-30-2005 04:13 PM
Rear Window Noise bubbachong Interior & Exterior 2 12-29-2003 11:40 PM
