Old 11-21-2005, 01:49 PM
lakemisurfer's Avatar
2003 Toyota Sequoia
Last Online: 02-01-2010 07:58 AM
Images: 5
lakemisurfer may have some regrets.
lakemisurfer's Photo Albums
Default 03 Sequoia CV Boots
Just visited the stealer. Sure enough inner CV boot spraying grease. I have a Revtek lift on this truck, they told me to take it off. I calmly said 'ha'.
Question's are: Will the ball joint recall affect this boot?
Revtek claimmed the angle was safe for CV boot wear??
I may have tore it over articulating, is that possible?
And finally, $650 for both inner and out boot repalcement....I thought I'd have them fix the boot while doing the ball joint recall, whould that save me $ ?
I signed up for this thing for help, hopefully you boys can give me some support, thanks.
Matt
2003 SR5 Loaded Sequoia, 2 1/2" Revtek Lift. Pro Comp Cast Blast 7189 wheels, 305 Nitto Terra Grapplers, Bull Bar w/PIAA 525's, MagnaFlow Cat Back, Hella Blue 80W headlamp bulbs, upgraded fogs Hella Blue 9005s. Centric slotted and drilled rotors w/Porterfield Carbon Kevlar pads at all corners www.wheelersoffroad.com
No more running boards~!
Old 11-28-2005, 09:42 PM
TLB TLB is offline
Dealer : Tony Divino Toyota
2005 Toyota Sequoia,
1998 Toyota 4Runner
Last Online: 02-24-2010 05:52 PM
TLB may have some regrets.
TLB's Photo Albums
I can't comment on the ball joint issue, however overarticulating . Your vehicle along with any other 4x4 should have some way to limit suspension travel. These can include shocks or bumpstops. My Isuzu Rodeo was limited by the shocks and bumpstops. My 05 Sequoia from looking around has bumpstops, and is also possibly limited by the front shocks. Especially on a independent suspension, the engineers know they have to limit front travel so you don't ie. tear a boot or blow a cv joint through excessive suspension travel. It is also the dealerships responsibility to show that your modification caused the failure, not just say oh darn you lifted it your fault (Moss-Magnuson consumer protection act). You might consider measuring the suspension travel of a stock unit and then measure yours and see how much difference there is if any, then head back to the dealer.
Good Luck,
Tim
Old 11-30-2005, 12:46 PM
RA RA is offline
Dealer : Toyota of Kirkland
2003 Toyota Sequoia
Last Online: 11-16-2006 10:51 AM
RA may have some regrets.
RA's Photo Albums
Default Matt
I have had the Revtek lift on my '03 Sequoia for over two years and have not had a CV boot problem.
Old 11-30-2005, 12:59 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 89
dyogim is a splendid one to behold. dyogim is a splendid one to behold. dyogim is a splendid one to behold. dyogim is a splendid one to behold. dyogim is a splendid one to behold. dyogim is a splendid one to behold. dyogim is a splendid one to behold. dyogim is a splendid one to behold. dyogim is a splendid one to behold. dyogim is a splendid one to behold. dyogim is a splendid one to behold.
dyogim's Photo Albums
Was grease coming from the sides of the boots or were the boots actually split open along the fins. If it's just coming out of the sides, replace the clamps with some hose clamps you can purchase from your hardware store. The wear on the boots will happen at any height more than stock. For some sooner than others. On my tundra, I had stock boots with 2.5" of lift with no tear in the boots. Only had to replace one hose clamp.
$650 You can probably get some new CV shafts and installed for that price. As far as saving money, possibly not, because you don't have to remove/disconnect the ball joint to remove the cv shaft.
If you don't mind getting your hands dirty and you have time, do the boot replacement yourself or have another toyota shop or off road shop do it for a cheaper price.
Mike
http://dyogim.blogspot.com
Old 11-30-2005, 10:23 PM
2003 Toyota Sequoia
Images: 5
Default Inner
It looks like it is come from around the clamps. The passenger side had more grease sprayed than the driver side. I wiped it all off and will see if anymore comes out. I don't off road often but I was in some back woods while bow hunting. Is it possible that the grease came out for a short spurt while over articualting? Maybe it will be fine while road driving?
Thanks for all the help so far!
Matt
Old 12-01-2005, 12:09 AM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 89
Matt
It's possible. If the fins aren't busted, change the clamps. Before you change the clamps, it would be a good idea to refill the boot with some more grease. However, I'm sure there's still a lot in there.
Mike
Old 12-01-2005, 01:27 PM
2003 Toyota Sequoia
Images: 5
Default Fins
I need a description on what the fin is and looks like....
Old 12-01-2005, 01:52 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 89
Is there a split/cut along the valley/crest(fin) of the CV boot?
Mike
Old 12-01-2005, 03:30 PM
2003 Toyota Sequoia
Images: 5
Default Ah Ha!
I thought thats what you meant. I see no tears or splits on the fins anywhere. As I said it seems to have come out past the clamps. I wiped it down last nite, if there isn't any grease there in a week, I am going to assume it's fine.
Does the boot and clamp spin with the shaft?
Old 12-01-2005, 04:10 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 89
Yes it does.
Mike
Sequoia Reliability dano100 1Gen-Sequoia 17 06-19-2009 08:02 AM
05 sequoia p2000 1Gen-Sequoia 3 08-21-2007 04:57 PM
Sequoia or Armada? ausk9-0 1Gen-Sequoia 30 07-30-2007 06:41 PM
Just replaced boots with porsche 930 boots, question leadsled Suspension & Axle 1 07-31-2004 12:46 PM
Sequoia or 4runner?? burch2217 1Gen-Sequoia 31 04-26-2004 01:08 AM
