2003 Sequoia horn problem
+ Reply to Thread
Results 1 to 8 of 8
Thread: 2003 Sequoia horn problem
  1. #1
    Join Date
    Nov 2005
    Location
    Minneapolis, MN
    Posts
    11
    Liked
    0 times
    Rep Power
    0
    Default 2003 Sequoia horn problem
    First timer here...looking for help,of course, but have found lots of stuff already on this site that has helped me. Right now, I have a shorted horn wire. I have continuity between ground and the 'black-yellow' coming off the clock spring, and also between ground and the red-white wire in the fuse block. I should not see that as the 'make ground' on the horn relay closes the horn power circuit. I have a wiring diagram from Toyota that shows a "HORN ECU" and that is where the 'blackyellow' wire turns to 'white-red'. Where is that ECU? For the life of me I cannot find it. I know it is not engine side of the firewall.
    Thanks in advance!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter 42GAMI's Avatar
    Join Date
    Jun 2004
    Location
    808-state
    Posts
    1,677
    Liked
    0 times
    Rep Power
    14
    welcome to TS. im sorry i cant offer much help, but i bet a buch of TS.ers will chime in soon. meanwhile, till the horn gets fixed, id just use my finger.
    MODS: (TRD Urban package) - tint, stereo, jack-in-the box antennae ball, and my middle finger.
    ~ been there, done that, got the panties ~
  4. #3
    Assistant Administrator nhparrot's Avatar
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    62
    Posts
    6,434
    Liked
    23 times
    Rep Power
    1673
    The horn is connected to the Body ECU and activated by the Body ECU during warning of the theft deterrent system or when the horn switch is turned on. The Body Ecu is behind the instrument panel, it is not something for the a "novice shade tree mechanic" to be fooling with.
    ~Glenn
    Yes I am a pirate!
    "To err is human. To arrr is pirate."
  5. #4
    Join Date
    Nov 2005
    Location
    Minneapolis, MN
    Posts
    11
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks for the info. I don't want to touch it! Any thoughts on why the horn circuit is shorting to ground? This is a rebuild salvage vehicle that took a right front hit and the horn short one of two things I have yet to fix. I guess it could be something in the anti-theft. Thoughts?
    The other issue, and I'll start a new thread on this, is the drivers airbag. I get 9.6V across the connector coming from the clock spring. Should be zero, right? I have brand new computer, sensors and bags. Passenger side is fine. The drivers side connector at the bag was melted during deployment of original bag. But the wires are fine. Any idea why I would see voltage there? Thanks!
  6. #5
    Join Date
    Mar 2005
    Location
    Milford, CT
    Age
    41
    Posts
    30
    Liked
    0 times
    Rep Power
    11
    I dont know about you guys but I couldnt see driving such a large vehicle and having such a wimpy factory horn. Find the horn trigger coming out of the column it should be a ground a hook up a relay and a loud horn. I hooked up a whelen 100 watt air horn it really gets peoples attention.
  7. #6
    Join Date
    Nov 2005
    Location
    Minneapolis, MN
    Posts
    11
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    And the anti-theft still sounds on the original horns?
  8. #7
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    62
    Posts
    6,434
    Liked
    23 times
    Rep Power
    1673
    Quote Originally Posted by Robc
    Theft Deterrent System triggers the horn and a second theft deterrent horn.
    Robc - see http://www.tundrasolutions.com/forum...-horn-problem/
    ~Glenn
    Yes I am a pirate!
  9. #8
    Join Date
    Nov 2005
    Location
    Minneapolis, MN
    Posts
    11
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks so much for all of the information! I did narrow it down to the body ECU. I did not attempt to modify/fix it...I just by-passed it and the horn works normally. I think the security horn alone is enough alarm for me. Everything else that goes througth the body ECU seems to be working, so that's kind of a head scratcher! Thanks again!
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. Problem Sequoia
    By sictoyotaowner in forum 1Gen-Sequoia
    Last Post: 11-22-2005, 11:39 AM
  2. Bizarre problem in 01 Sequoia
    By seqlady1 in forum 1Gen-Sequoia
    Last Post: 07-07-2005, 01:55 PM
  3. INFO: 2003 Sequoia Audio System Information
    By nhparrot in forum Knowledgebase Archive
    Last Post: 01-30-2005, 02:54 PM
  4. How to do Foglight mod on 2003 Sequoia?
    By Plamar in forum Electrical & Computer Systems
    Last Post: 04-07-2004, 02:11 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
