Firing Order and Cylinders Layout
+ Reply to Thread
Results 1 to 3 of 3
Thread: Firing Order and Cylinders Layout
  1. #1
    Join Date
    Nov 2005
    Location
    Houston
    Posts
    11
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    Question Firing Order and Cylinders Layout
    Does anyone have the Firing order and the Cylinders layout (number label)?
    I think they are all the same right?
    02 Sequoia......
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member mcmatt's Avatar
    Join Date
    Feb 2002
    Location
    Austin, TX
    Age
    48
    Posts
    189
    Liked
    2 times
    Thanks
    0
    Rep Power
    404
    Default Re: Firing Order and Cylinders Layout
    I was looking for the same information and I came across your message. I found the answer in a Haynes manual. I can't believe how hard this is to locate. I have ALL the factory service manuals. I guess they don't waste time on what they think is simple. I actually found the WRONG info in a Toyota TSB.
    Anyway, I had a P0301 code for cyl 1 and this got me to the correct igniter coil.
    Front of vehicle ^
    1........2
    3........4
    5........6
    7........8
    All of the injector connectors have a Black with red stripe wire. The corresponding other wire color on the injector connector that matches with above are
    red.........................white
    green......................Red/black stripe
    blue........................yellow
    blue/red stripe..........Red/white stripe
    This is a corrected post and is verified with the service manual and the electrical service manual for a 2001 Sequoia.
    Good Luck,
    Matt
    I know this is way too late, but maybe useful to someone.
    Matt
  4. #3
    Join Date
    Dec 2012
    Location
    leesburg
    Posts
    69
    Liked
    11 times
    Thanks
    0
    Rep Power
    20
    so if i am looking down onto the engine in front of my truck, from the bumper to the windshield, on
    the left they go 2,4,6,8, on the right 1,3,5,7 ? ?
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
